anyone installed an 04 sti ebrake lever in a 91 legacy?
is it just plug and play?
04 sti ebrake lever in 91 legacy
Re: 04 sti ebrake lever in 91 legacy
Bolt.holes don't line up. And IIRC it was on the wrong side of the center console.
thanks. what's a good upgrade? mines is looking pretty ratty.mike-tracy wrote:Bolt.holes don't line up. And IIRC it was on the wrong side of the center console.
Probably isn't much out there for an upgrade. But I bet you can find a better looking handle at your local you pull it yard.
