WANTED: Perrin Lightweight Crank Pulley
NuclearBacon
Post by NuclearBacon »
Or another aluminum pulley that has lightweight characteristics for the crankshaft.
I spun mine. dangit!!!
Thank you!!
Luigi
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
ej22tVermont
Re: WANTED: Perrin Lightweight Crank Pulley
Post by ej22tVermont »
I know from previous experiance with a 99 RS, that if you do not have the crankshaft matched to pulley, your engine will fail extremely prematurely. Blew two motors due to this mistake. Perrin makes the pulley, and the crankshaft specially balanced for the setup you are looking for.
Adam West
Post by Adam West »
I have one AND a lightweight flywheel...double trouble. Or so I've heard. But so far so good. Redlined it a bunch at the track too. Not sure what to tell you beyond hitting up Nabisco a bunch. I see them a lot there.
dropdfocus
Post by dropdfocus »
I installed the Perrin LCP on my ex-wife's 2.5LGT over 2 years ago with no problems and the car has not been treated nicely either.
Jason
NuclearBacon
So wait... How much for just the pulley? shipped to 95928 I already have a lightweight flywheel. I only need the pulley.
-Luigi-
dropdfocus
DO NOT mix the LCP with a LWFW!!! You will absolutely hate the results from it. You will run into idling problems and such from lightening both ends of the crank attachments. Pick either the FW or the CP but not both. I've seen it first hand it's not something you want to experience.
Jason
greg donovan
Post by greg donovan »
ej22tVermont wrote:I know from previous experiance with a 99 RS, that if you do not have the crankshaft matched to pulley, your engine will fail extremely prematurely. Blew two motors due to this mistake. Perrin makes the pulley, and the crankshaft specially balanced for the setup you are looking for.
i dont think that is true.
the part number is the same for a 93-01 impreza and a 02-09 na 2.5 is the same and the same as the part number for a WRX.
they only make one pulley.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Lunatech
Post by Lunatech »
Well, that's all fine and dandy, but the boy is looking to make a purchase, not hear all the pros and cons.
Can anybody help him out?
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
dropdfocus
The point of the pros & cons is that this will be a wasted purchase if he's already running the light weight flywheel.
Jason
greg donovan
Lunatech wrote:Well, that's all fine and dandy, but the boy is looking to make a purchase, not hear all the pros and cons.
if i see bad info that will affect his purchase i want to help.
96 Impreza L sedan
00 Impreza RS sedan
Bheinen74
Post by Bheinen74 »
there be one on craigslist WI milwaukee
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
NuclearBacon
dropdfocus wrote:DO NOT mix the LCP with a LWFW!!! You will absolutely hate the results from it. You will run into idling problems and such from lightening both ends of the crank attachments. Pick either the FW or the CP but not both. I've seen it first hand it's not something you want to experience.
I've put more then 70,000 miles on my car with this mod (LW flywheel + LW pulley) with the smoothest idle. It has 240,000 miles now and idles better then my buddys wrx with 6000 miles on it. I also have group N mounts, and still idles amazingly well. First hand .. It works juuust fine.
So anyone have one for me to purchase before I go to nabisco??? :)
bumpity bump bump
-Luigi-
