FS in Ga 92 SS Parts + Misc Impreza Bits
Hey guys, I've begun to sort through the leftovers from my swap. All parts came from a 92 SS unless otherwise noted. I may have a few more odd bits as I finish digging through everything. All parts will ship from Ga zip code 30022. Buyer pays shipping. Prices are OBO so worst case is you ask and I say no. The quickest way to reach me is by text: 67eight-four57-o7o3 Thanks for looking - Ben
* LHD Gauge Cluster Surround: In perfect condition - $30
* Front Grill Insert: Center delete and painted white, I used body filler and mesh which cracked, Id recommend using fiberglass to smooth it out - $15
* USDM Corner Tails and Center: Missing the Subaru badge and a couple mounting screws rusted, there is a small crack in the clear plastic of the pass side corner which is in the plastic and did not leak - ~ SOLD ~
* OE SS Spoiler with 3rd Brake Light: LED's work, the paint is flaking badly - ~ SOLD ~
* HVAC Controls: Buttons have the usual cracked paint, everything works - $20
* Radio with Pocket: Pocket door still works but slips off the spring, needs plastic weld, radio is good - $20
* MT Shifter Surround: Its durdy, Ill clean it up before shipping, 5spd badge was removed - SOLD
* Steering Column Surround: Has a clamp screwed into it, held a gauge - $5
* OE Power Antennae: Worked when the car ran last about 1 year ago - $40 ` SOLD
* USDM Headlights: No cracks in the lenses, yellowed inside, some plastic tabs are broken but they mounted fine, good set if you want to try your hand at the clear lens mod - $50
* USDM Signal Lights: Drivers side fender tab snapped off when someone hit the car while parked - $12
* Fender Reflectors: $5
1995 Impreza LX AWD Spring Set: I haven't taken the front set off the car yet - $15
1992 SS 5MT
Re: FS in Ga 92 SS Parts + Misc Impreza Bits
Dont be shy, offers will be considered.
1992 SS 5MT
$125 for Corner Tails and Center + spoiler?
Subaru Legacy BF Wagon 1.8 EDM to 2.2 N/A Swap
lucesdisco, thanks for the interest. Pm has been sent.
1992 SS 5MT
OE Power Antennae
still for sale?
still for sale?
Hey prodrive. It is still available my friend. Thanks - Ben
1992 SS 5MT
Sale of the full tail light sections and spoiler are pending.
1992 SS 5MT
Stay tuned. More parts going up this weekend.
1992 SS 5MT
Sale pending on the power antenae.
1992 SS 5MT
Sorry guys, the additional parts will be up soon. I ended up spending the weekend helping a buddy rebuild a block.
1992 SS 5MT
MT shift surround pending sale. Thanks guys!
1992 SS 5MT
did that shifter surround sell?! im interested!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
'91 Black SS - SOLD
Hey Kris. Thanks for your interest. It is still available. Another member advised my pics looked black on his browser so to clarify. All trim from the SS is the slate blue/gray color that came in the white '92 models. The surround trim sat outside for a couple of days and has some fading and staining. Though physically functional its not exactly pretty.
The package specs are below if you want to figure out shipping.
Est weight: less than 3lbs
Dimensions: 18l x 13h x 6 deep
Thank you! - Ben
Thank you! - Ben
1992 SS 5MT
Haha I know how to use black spray paint haha I'll pm you
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Center console pocket has been sold! Thanks Kris!
Ill have a few more bits and pieces available soon including a 5mt turbo drive shaft and 4eat automatic drive shaft off of the 95 Impreza L. Stay tuned peeps.
1992 SS 5MT
Hey you said the cubby pocket was sold but was the radio? Do you have the radio trim too?
Hi Watertree92. Thanks for your interest. I do still have the radio. Ill have to check on the trim however. One trim piece is already sold but I may have another for the same color interior. Thanks - BenWatertree92 wrote:Hey you said the cubby pocket was sold but was the radio? Do you have the radio trim too?
1992 SS 5MT
still happen to have those springs? what kind of difference are they vs stock turbo wagon springs if so
'94 Legacy Turbo Touring Wagon; kyb gr2's/mostly stock
'05 Toyota Corolla XRS - 1.8L 2zz-ge, 6speeds of revtastic fury
