I am in need of a PVC Connector for a 94 turbo wagon. Subaru part number is 11821AA350, there are none available anywhere in US according to Subaru. Looking for a used one. The piece I'm needing is the metal tubing that the 2 hoses connect to that come from both valve cover vents which also connects to the block in the middle of the metal tubing (it hides on the bottom side of the intake). Here is a picture of it, its item 14:
[URL=http://s1093.photobucket.com/user/ ... .png[/img][/url]
Thanks for the help everyone...pete
In Need of PVC Connector
1994 Legacy Sport Wagon (EJ22T)
1977 Leone 4X4 Wagon (EA72)
Re: In Need of PVC Connector
If you're talking about #14, then it's actually made of plastic. I had a heck of a time finding an intact one, so I used bulk PCV hose and a plastic "T" joiner (that I trimmed down a little to fit). hose # 11 is super brittle too, but my T replaces that.
Hmmm, that's odd. I was pretty sure mine was like 3/8" steel tubing. My #1 and #12 are plastic for sure and you are correct on #11, mine was super brittle as well.
I'm positive it's plastic. I *might* have one left if you really want it. Won't be able to search for it till I get back on monday though.
That would be awesome, yes please. Thanks man
I was unable to find it anywhere. I encourage you to make your own from bulk pcv hose and a T connector.
I made a custom setup copper pipe and and tees to replace all the plastic hoses. 3/8" is the size for all of it
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
I might have one here shortly but like Mike said, it'd be much cheaper and easier to use pcv hose and a T
