Walbro 255 Fuel pump
Got a new part? Is it the best thing you've ever seen? Is it a complete ripoff? Let us know about your parts and service.
Post by SubaruNation »
I couldn't find a thread for it in here already, so lets start one!
Not really much to say other than it's awesome and i highly recommend it.
Like people said in other threads i found, i don't know why you really wouldn't get one as a replacement for the stock one.
they're cool also because of how much smaller they are than the stock ones, except they run better?
Crazy.
I would like to thank 93firestpearl for his help when i was swapping out the stock Pump also.
Post by SILINC3R »
is this good for a stock car and how much and how difficult
BSOD2600
Re: Walbro 255 Fuel pump
Post by BSOD2600 »
SubaruNation wrote:I couldn't find a thread for it in here already, so lets start one!
Here is my install thread with more pics.
SILINC3R wrote:is this good for a stock car and how much and how difficult
* Yes, works fine in a stock car.
* I paid $133 for mine at subaruparts.com Walbro GSS341 255lph
* It's fairly easy -- at least in a Wagon. Heard its more of a hassle in the SS due to the seats/trunk in the way of things. Have to carefully get the fuel sender pod out of the small hole in the tank with lots of twisting for clearances, etc.
'11 WRX Limited
'94 TW | R.I.P.
yeah, in the review section though. but it all works :)
i would say yes it's very good. i feel a huge difference in the driving and acceleration, but i didn't just do a fuel pump :D.
you might as well, especially if you are planning on increasing the boost
BTW,
You want the GSS341 pump not the GSS342 pump.
There's also an adapter kit, 400-791 you can buy with the GSS341 pump that makes it a plug & play affair.
BSOD2600
Post by BSOD2600 »
Really? whats the difference between GSS341 pump not the GSS342? Just the position of the inlet/outlet, right?
Mine was plug-n-play. I recall it came with a new filter, and the wires hooked up just fine.
'11 WRX Limited
'94 TW | R.I.P.
thanks josh, yeah i bought the GS341 kit off eaby for $100 and it came w/ everything needed for the swap.
Not sure.....when I bought mine I did some looking and that was what I found.
BSOD2600
Post by BSOD2600 »
Well Josh is right, you DO want the GSS341 pump. I was mistaken in my earlier posts and thought I got the GSS342. Swapped pumps with the SS today and had a chance to compare the stock vs walbro I had installed a while ago.
Anyways, the GSS341 is a direct replacement:
'11 WRX Limited
'94 TW | R.I.P.
Airgne
Post by Airgne »
got a 02 wrx kit that bolted right in paied 182 shipped. easy as hell to install. easy mod and a good one.
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
SubiePrice88
Post by SubiePrice88 »
so wheres the best place to buy the Walbro 255 GSS341 with everything needed?
Im still a little stumped and kinda hate buying certain stuff online when I cant actually see it in person.
I just want to get the right pump with everything needed
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
asc_up
Post by asc_up »
You can get one right from the Subaru dealer. I did for $100 + tax.
SubiePrice88
What about this one?
http://www.walbro255.com/255-lph-high-p ... 59801.html
Its $95.00 with free ground shipping
I believe its the right one...
Thanks for the help!
-Jordan
Redlined
Post by Redlined »
yup.. thats the correct one and for $25 bucks less than everyone else
darkcrave
Post by darkcrave »
Could a walbro overwhelm the stock injectors if you have 0 mods?
Tune
TMIC
Fuel
Taillight
darkcrave
Post by darkcrave »
Tune
TMIC
Fuel
Taillight
BSOD2600
Post by BSOD2600 »
Overwhelm? As in the injector couldn't control is duty cycle? I have my doubts, as many on the board have run the walbro with stockish setups and no problems. How ever, if your injector oring seals are bad, then the increased fuel pressure I suppose could cause some leakage.
Why do you ask?
'11 WRX Limited
'94 TW | R.I.P.
darkcrave
Post by darkcrave »
just wondering if a fuel pump going from so low to 255l would be pumping "to much fuel"
Tune
TMIC
Fuel
Taillight
Redlined
Post by Redlined »
Fuel pressure is regulated just before the injectors. Running the Better pump simply insures sustained pressure at higher than normal Fuel consumption rates (bigger turbo, more boost, bigger injectors etc) there is no risk to running it with stock components. Infact some people on the board have commented on performance gains over the stock unit using stock components
darkcrave
Post by darkcrave »
Installed the Fuel pump today! Walbro makes some great stuff! installed with easy! Highly recommend purchasing the install kit that they sell with it!
Tune
TMIC
Fuel
Taillight
TurnNburn
Post by TurnNburn »
Got mine in the mail today. $95 bucks with the kit from Injectedperformance.com with free shipping. They even included a little die cast Hatchi Roku AE86 drift car. Kind of an unexpected addition to my order. lol. Will install tomorrow but i was curious if people were re-using the gasket that goes around where the unit seals against the gas tank. Iv read several threads but no one has mentioned it so it must not be a big deal to use it again (unless it looks like doo doo of course)but i was just curious.
1990 NA 2.2 Open Light rally car
The rubber gasket is fine to reuse unless you see that it's torn or damaged.
TurnNburn
Post by TurnNburn »
Install went great. A little tricky getting the assembly out of the tank though and the old pig tail didnt want to come out without a fight (good thing i got the adapter kit which had a new one in it.) It is a tiny bit louder which isnt surprising considering how much it flows versus how small it is.
+1 for being painless.
Went around my usual stomping grounds after the install and i felt that it stuttered way less when initially hitting full boost, 15psi @3-3.5k rpm. Which is why i got it in the first place. Definitely need to roll around more to be sure though.
Dominator
Post by Dominator »
I know this is an old thread, but it's a bump on topic at least.
I ordered the "Walbro GSS341 Fuel Pump" and "Walbro 400-791 Fuel Pump Installation Kit" from Amazon to install into my 1991 Legacy SS to prepare for an autocross that's coming up soon. I'm feeling some stuttering when I use heavy throttle, so I'm hoping this mod will help ensure that fuel delivery is ruled out for that symptom. This is also to prepare for the Rob Tune upgrades I'm installing later this summer, so I need to upgrade for that anyway. I also ordered a Holley Hydramat (PART# 16-111) for this install too. This is an expensive part, but it is amazing. I replaces the fuel pickup sock. If you haven't heard of it before, check out the video from the link below. I put one on my 1997 Legacy after running it at the first autocross. I was getting severe fuel starvation on long right hand turns. I had to run with a damn near full tank to avoid starvation. After the hydramat was in place, I ran that car with lower than an 1/16 tank of gas showing on the gauge. Here's the links. I'll post up anything remarkable after I'm done with the install.
Walbro GSS341 Fuel Pump I paid $53.19
https://www.amazon.com/gp/product/B000EVPCFS/
Walbro 400-791 Fuel Pump Installation Kit I paid $22.21
https://www.amazon.com/gp/product/B000EVTKTC/
Holley Hydramat (3x15) 11MM Outlet w/6 Lock Pin Position PART# 16-111 I paid $163.95 plus shipping.
https://www.holley.com/products/fuel_sy ... rts/16-111
That Hydramat looks pretty cool!!
Thanks for sharing!
