Moderators: Helpinators , Moderators
turbo970
Posts: 859 Joined: Sun Jul 15, 2012 11:50 pm
Post
by turbo970 » Wed Jul 17, 2013 10:06 pm
so which way is right this one
or this one
the second one is based a wiring diagram below
still ildes high. the first pic is how i recieved the car back
turbo970
Post
by turbo970 » Thu Jul 18, 2013 2:52 am
ttt
Posts: 2763 Joined: Wed May 30, 2007 6:11 am
Post
by SILINC3R » Thu Jul 18, 2013 2:57 am
should be like the first one. did you do the feeler gauge test?
92ss satinsvoice wrote: LOL! that block was like F*** THIS! IM OUT!
mike-tracy wrote: Word. I'd love to get my hands on one of those trannies, but I just can't stomach the cost
turbo970
Post
by turbo970 » Thu Jul 18, 2013 3:10 am
i just switched the wires after i saw the diagram. i'll switch it back. i wonder why diagram shows it brown white black red?
turbo970
Post
by turbo970 » Thu Jul 18, 2013 3:46 am
ok i switched it back so its like the first pic. when i drove it while it was wired like the diagram that thing shifted better and had sum wicked pull lol. just idled high
turbo970
Post
by turbo970 » Thu Jul 18, 2013 4:37 pm
well i drove it again this am with the wires set up in the first pic. car shifts crappy again. bust shifts better with the wires set up in the second pic
Post
by SILINC3R » Fri Jul 19, 2013 2:49 am
Have to double check my car. But also i think cleaning up those wires would help out a lot also.
turbo970
Post
by turbo970 » Fri Jul 19, 2013 4:00 am
i will i'm getting some red loom. and red tape. til i get everything set right i'm gonna keep them out like that. i know the tps is way off because it wont kick down when i hammer the throttle
Posts: 27932 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Sun Jul 21, 2013 6:12 pm
Both are wrong!
Here is how they should be wired up.
http://www.main.experiencetherave.com/s ... sconnector
Just to note that my pictures are from the opposite side of the electrical connector. Also, yes if you can clean up that wiring, I'm sure that will help, but pinning them correctly should make things much better.
turbo970
Post
by turbo970 » Sun Jul 21, 2013 8:23 pm
sweet thanks again josh. you took one look saw it was wired wrong and yet the shop couldnt lol
