PP6 wiring ?'s
94legacy2.2
PP6 wiring ?'s
Post by 94legacy2.2 »
so I got my pp6 finally and the wiring harness colors dont look like 777legacy's pictures Ive seen. The pin outs on it look good just colors are different.
Now ?'s are, im confused on what actually gets hooked up
here is a pin out from douglas hostings.
Maybe someone can say or write out something like pin #11 (pp6) to pin # b48.7 (car)
or if you have a better way please let me know. I made a plug and play harness out of a spare ecu so i wanted to hook it up before its installed and try it out
SMT6
DESCRIPTION
COLOUR
1
Ground, GND, Chassis
Black
2
RX-Input
3
TX-Output
4
Map switching
Grey
5
IG2IN
White / Red
6
AIN, Analog input
Blue
7
A-DEFL, Analog deflection input
Brown
8
IG1IN, Also RPM deflection
Yellow
9
Injector, chassis, current
Green
10
AMP input
Black / White
11
Engine Temp
Green / Yellow
12
NC
13
+13V, Battery
Red
14
Pull-up 4K7
Blue / Black
15
Pull-up 4K7
Blue / Black
16
AUXOUT
Orange
17
IG2OUT
White / Blue
18
AOUT, Analog output
Violet
19
IG1SP, Bipolar output of IG1
Pink
20
IG1OUT
White
21
Injector +, to injector, current
Grey / Black
22
Oxygen input
Black / Brown
23
NC
24
NC
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
n2x4
Re: PP6 wiring ?'s
Post by n2x4 »
94legacy2.2 wrote:so I got my pp6 finally and the wiring harness colors dont look like 777legacy's pictures Ive seen. The pin outs on it look good just colors are different.
Which diagrams are you using and what car are you trying to match it up to?
SUBARUEHS Racing
94legacy2.2
ok so this is what I have so far
pin 1 (pp6) to ground
pin 2 (pp6) to B56.7 (tap into) ????? is this right
pin 3 (pp6) to B56.8 (tap into) ????? is this right
pin 4 (pp6) to leave disconnected (map switch)
pin 5 (pp6) to F47.10 (cut wire, connect to ecu side)
pin 6 (pp6) to B48.9 ( cut wire, connect to harness side)
pin 7 (pp6) to B58.2 (tap into)
pin 8 (pp6) to F47.9 (cut wire, connect to ecu side)
pin 9 (pp6) to ?
pin 10 (pp6) to ?
pin 11 (pp6) to b48.7 (tap into)
pin 12 (pp6) to n/c
pin 13 (pp6) to B48.2 (tap into)
pin 14 (pp6) to F47.9 (tap to pin 8 on pp6 side)
pin 15 (pp6) to F47.10 (tap to pin 5 on pp6 side)
pin 16 (pp6) to ?
pin 17 (pp6) to F47.10 (wire already cut, connect to car/motor side)
pin 18 (pp6) to B48.9 (use cut wire, connect to ecu side)
pin 19 (pp6) to ?
pin 20 (pp6) to F47.9 (wire already cut, connect to car/motor side)
pin 21 (pp6) to ?
pin 22 (pp6) to hook to wideband input 0-1v
pin 23 (pp6) to n/c
pin 24 (pp6) to n/c
94legacy2.2
94legacy2.2
no I dont have the manual, the guy I bought it from said it was complete then I get it and its missing the cd, tuning cable, directions and bridge so I had to order that stuff from PP.
thanks for the links above, ill use them once Im ready to install it all. Just a few other questions with wiring it.
pin 9---Injector, chassis, current
pin 10---AMP input
pin 16---AUXOUT
pin 19---IG1SP, Bipolar output of IG1
pin 21---Injector +, to injector, current
Pin 10 amp input, does this just tap into the map sensor for signal? Will this work injunction with the FCD?
and pins 9-21, these are injector wires, how are these hooked up?
Sorry for the questions, I did search and didnt really see much info on actuall wiring it
The AMP input, yeah it just taps into the MAP sensor signal. Assuming you are using an electrical FCD, you would need to tap into the MAP sensor signal wire BEFORE you go to the FCD to ensure that you get an accurate reading and not a "capped" value.
Pins 9 & 21 are for an auxilary injector. You should not have to mess with this.
