»  BC-BF Legacy Discussion »  Electrical
#connecting rear defroster wires
Custom Search
Login | Register
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: connecting rear defroster wires
PostPosted: Mon Oct 25, 2010 4:11 am
When I bought my wagon the rear defroster wires were disconnected from the window. I was wondering what to use to reconnect them to the window. I would realy like to be able to defrost my rear window without rolling down my rear windows and letting the freezing cold in. :)
90 2.2 N/A legacy awd wagon with outback struts.
Profile  Offline
 Post subject: Re: connecting rear defroster wires
PostPosted: Mon Oct 25, 2010 4:55 am
were the connectors cut off or missing?
Profile  Offline
PostPosted: Mon Oct 25, 2010 9:26 am
They were broke off of the window. On the end of the wire is a metal plate and it connects to a thick spot of the metal that makes up the defrost lines on the window that is shapped just like it. I am thinking some kind of liquid metal that will harden after applying will work but I'm not sure. I don't know if it needs something special to adhear it to the metal on the window to keep good connectivity for the electricity to pass through it or not.
Profile  Offline
PostPosted: Mon Oct 25, 2010 4:35 pm
check this page out half way down and see if it helps.
http://www.frostfighter.com/fixit.htm
http://www.popularmechanics.com/cars/ho ... ce/4221212
Profile  Offline
PostPosted: Mon Oct 25, 2010 10:58 pm
Yup, any local auto shop should have the repair kits for them.
'11 WRX Limited
'94 TW | R.I.P.
Profile  Offline
PostPosted: Tue Oct 26, 2010 1:02 am
Thank you. That's exactly wut I needed to know.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 2 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
