I've got a 1991 Legacy SS sedan that I swapped a 1994 Legacy Turbo Wagon engine into. My problem at hand is the difference of the engine plugs between the MY90-92 and the MY93-94. I didn't know about the differences until I got the newer engine in there.
In this picture I show the (1991) chassis side harness 2 square and one rectangle, coming out under neath the engine bay fuse box (in my hand). Also in the photo is the (1994) engine plugs which are 1 square, 1 rectangle and 1 round (zip-tied to the intake).
I don't have the 91 engine harness, but I've got the whole 94 donor car, so I could swap that chassis harness into the 91. I need to learn more about that. And find out if it will match up and plug in the same on the other end and where that is. Does it plug into the ECU or fuse panel or what. That's my dilemma.
If you want to see more of this build so far, I have some documentation on my local forum at this link.
http://www.fairbanksforum.com/phpbb3/vi ... =11&t=7056
So, if anyone can give me suggestions, or threads that deal with this topic or are related, please let me know.
Thanks for your time,
-Dominic
