»  BC-BF Legacy Discussion »  Electrical
#code 31 TPS
Custom Search
Login | Register
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: code 31 TPS
PostPosted: Sat Feb 25, 2012 12:50 am
i got a code 31.(91ss with jdm ver2 ej20g and ecu)
it comes on right after ignition on.
clear the code but still comes back.
perform input and output test.
i got 4.6v on closed and 0.5v on WOT
any idea?
Profile  Offline
 Post subject: Re: code 31 TPS
PostPosted: Sat Feb 25, 2012 3:05 am
Are you measuring the voltage at the ECU pins or at the TPS?
How does the car drive? Does it stumble when you first press the throttle?
Profile  Offline
PostPosted: Sat Feb 25, 2012 4:16 am
i measured it from ecu pins.
car drive normal but it stumble when i first press the throttle.
Profile  Offline
PostPosted: Sat Feb 25, 2012 5:04 am
Hmm, that's odd. All I can think of is that either the harness connector isn't making good contact with the ECU pin, or there's a problem inside the ECU.
It might be possible to pull the contact out of the harness connector and kind of bend the metal slightly to make it grip the ECU pin more firmly.
Did the problem just come up out of nowhere one day?
Profile  Offline
PostPosted: Sat Feb 25, 2012 5:36 am
problem started after i did ej20g swap
Profile  Offline
PostPosted: Sat Feb 25, 2012 5:48 am
Oh, so it's been there the whole time... How did you wire in the EJ20G ECU? Just used the stock wiring and modified it for the extra ignition channels? If that's what you did, and there was no code before, I guess that means the ECU is more likely. You don't have access to another ECU to test, do you?
Profile  Offline
PostPosted: Sat Feb 25, 2012 10:01 pm
found the problem.
worn out or loose pins cause code31.
replaced all three pins and problem fixed.
thanks
Profile  Offline
PostPosted: Sun Feb 26, 2012 5:56 am
Nice work.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 4 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
