Behind Dash Relay Location Guide With Pictures!
subytech
Post by subytech »
I'm in the process of rewiring my car and during the teardown I shot some pics and thought I'd make a guide to some common relay locations. The car is a 92 turbo sedan but these should be applicable to most of our cars. Sorry if the colors are hard to read, they seemed to be the ones that showed up the best. Hope this helps someone someday!
Pic One
Pic Two
This is a little more zoomed in than the box in pic one indicates, I know. For reference the off white box to the right and slightly below the horn relay is the fuse box under the dash on the left side of the drives foot well
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
Re: Behind Dash Relay Location Guide With Pictures!
I'm sure this will be Extremely helpful for some users. Thanks for posting. Josh, Can you sticky this?
Nice work!
I've added it to the sticky compilation thread.
http://bbs.legacycentral.org/viewtopic. ... 31#p309831
icrman
Post by icrman »
Nice work. Could you post a pic with the screw and bolt points that hold the whole panel in ?
subytech
Post by subytech »
Panel? do you mean the fuse panel or the bracket that holds the fuel pump and ignition relay? There is also a bracket that holds the horn and blower relay too.
Danny-G
Post by Danny-G »
Now I don't have to hunt around for the horn relay. This has saved me hours already and I've done nothing yet,
Danny
subytech
Post by subytech »
Glad I can help!
icrman
Post by icrman »
The whole dash panel.
That thing that stretches from driver door to passenger door, and from the windshield, to the drivers and passengers legs and has the radio, heater controls, glove box, instrument cluster, switches and all that stuff on it. That thing that is removed in the upper pictures to reveal all the wires and relays behind it.
subytech
Post by subytech »
Ah, well that would be a whole lot more pics and for a different forum. But I suppose I could do a write up when I reinstall the dash, but that wont be for awhile yet. I'm still gathering parts and laying out components of the harness.
damnsubi
Post by damnsubi »
how do i get to the ign relay?
Very small hands. Gotta reach way up there above the ecu.
85hpp
Post by 85hpp »
I would kiss the OP of this thread if i could. You da man!
Pete - '94 Legacy 2wd/auto - Mobile nightclub in progress
- '02 Legacy Outback Sedan Limited - heated leather seats, sunroof, shiny paint, cherry condition - all things new to me :)
- 2006 Honda Reflex 250cc
