underhood FCD
underhood FCD
i got a fcd from cj and been searching for what wires to tap into to install the fcd. does any one have the wire diagram for the MAP sensor or can take a pic of which wires to tap into
Re: underhood FCD
Re: underhood FCD
+5 is White
Ground is Red
Signal wire is Black
+12v comes from the Yellow/Red wire at the brown plug of the pressure exchange solenoid
I had to dig out my old car file from the filing cabinet. Had lots of other cool papers in there too.
Ground is Red
Re: underhood FCD
Thanks cj that helps alot
Re: underhood FCD
No problem man. I really thought the directions were in there. I apologize.
Re: underhood FCD
all hooked up and runs fine thanks again cj
Re: underhood FCD
Awesome!!!!!! You get your 14lbs?
Re: underhood FCD
i turned it down to 12 so i can keep track of my afr's but i'll bump it back up in a day or two
Re: underhood FCD
Sweet.
