86 Subaru Leone
originalcyn
Re: 86 Subaru Leone
Post by originalcyn » Tue Jun 04, 2019 5:15 pm
So good. Shaping up nicely!
Kijan
1993 Legacy LS | PBM 227
Re: 86 Subaru Leone
Post by Legacy777 » Tue Jun 04, 2019 6:09 pm
NICO wrote:
Tue Jun 04, 2019 4:09 am
I can't remember where I left on but lots of new stuff and building stuff has started
also decided to construct my own shifter setup because Subaru won't sell me there version
short video of the day & night shifter feel
https://www.instagram.com/p/Bju3YLXn3op ... _copy_link
Nico,
Can you elaborate on what you did to the shifter? I see you have upgraded bushing in the joint and pivot on the lever, but is there anything else you changed?
1997 Impreza OBS
NICO
Re: 86 Subaru Leone
Post by NICO » Wed Jun 05, 2019 5:08 am
yeah so far so good, body shop this week and motor work while I wait for paint work
NICO
Re: 86 Subaru Leone
Post by NICO » Wed Jun 05, 2019 5:12 am
Nico,
instead of rubber or plastic I made brass so copy original's, then that busing I pressed in was the same size as the rear control arms from svx pillow ball and made bushing to take the slack for bolt like stock.
the tricky part is the pillow ball with race and cup to fit in the lower section of leaver. clip to hold it all together
NICO
Re: 86 Subaru Leone
Post by NICO » Wed Jun 05, 2019 5:13 am
well here it is ready to get sent for paint and now we are all caught up with the build thread on the wagon.
insert EJ22T ( forged built bottom end ) EJ207 STi V8 big port heads, Turbo ?? maybe ( twin scroll / single scroll ) rotated & 6MT six speed STi R180 diff.
NICO
Re: 86 Subaru Leone
Post by NICO » Fri Jun 07, 2019 3:57 am
many parts have come in for the motor now its time to dig a ej22t block out and build it while I wait for paint work.
Wossner Made in Germany forged 22B pistons and connecting rods, STD size pistons means no messing around with my ej22t block & machine shop 👌.... I should have just built all my ej22T this way :rolleyes:
ACL racing STD size bearings not race version, STi spec-c oil cooler adapter, proper water pump with single port and old school timing belt tensioner from the ej22t aka the motorsports racing tensioner.
aurora asm-10T military aviation spec front control arm spherical bearings, this will all me to run longer aka normal Subaru length CV axles and also camber. I won't need to modify the front crossmember to except XT6 front control arms.
lots of mess 🙆‍♂️
originalcyn
Re: 86 Subaru Leone
Post by originalcyn » Fri Jun 07, 2019 5:29 pm
This reminds me of those "how to draw a thing" memes where it's just first draw a circle, then make a portrait.
Here's a table of parts, bam now we have a rad car. lol.
Thank goodness you're better at documenting things that a lot of people.
Kijan
Re: 86 Subaru Leone
Post by mike-tracy » Fri Jun 07, 2019 9:46 pm
I think the reason people usually go with oversize pistons is the cylinders sometimes aren't perfectly round after time. They become slightly ovaled and the boring out brings them back to basically perfect again.
Josh Colombo wrote:
Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
Re: 86 Subaru Leone
Post by Legacy777 » Sat Jun 08, 2019 9:29 pm
Ok, thanks for the explanation.
1997 Impreza OBS
NICO
Re: 86 Subaru Leone
Post by NICO » Thu Jun 13, 2019 5:13 am
lol lol thanks
NICO
Re: 86 Subaru Leone
Post by NICO » Thu Jun 13, 2019 5:14 am
yes correct, all the blocks I've owned seem to be fine over time
NICO
Re: 86 Subaru Leone
Post by NICO » Thu Jun 13, 2019 5:15 am
no problem if you make one need help let me know
NICO
Re: 86 Subaru Leone
ADDCO 22M front and rear sway bar set up for the wagon
Battery tray removed so I can slide them spark plugs in in seconds & front mount intercooler holes cut before paint work
hydraulic clutch slave holes drilled
BRZ koyo radiator fits like a glove
Re: 86 Subaru Leone
Post by Legacy777 » Thu Jun 13, 2019 5:57 pm
That's cool you can use BRZ parts :)
Regarding the shifter, I've been happy with mine. I used TiC's poly bushings on everything and it's very solid feeling.
1997 Impreza OBS
