The hose to the turbo was very close - I just cut off <1" where it connects to the turbo - the length from the Y-pipes to the 90' elbow was perfect. The small piece that connects the Y-pipes works, but it's a tad short. The 2 metal pieces that make up connection on the right are not aligned, but still worked.
I was able to get everything under the Pitch mount:
and had plenty of room.
I was able to rotate the tank 90', and use the same hoses. I'm using zippies to keep it in place, 'til I fab a bracket/mount:
Everything's working, running 13psi w/an MBC...only issue is the high idle when cold (1500+), and it takes longer to return to idle even when warm....I'll check Vac lines (again) and clean the IAC??
The PCV was a PITA as it had to be just the right height (I came off the crankcase w/a 90 elbow just under the turbo to IC junction), but eventually got it figured out.
Constructive criticisms welcome, as this is my first swap and turbo experience...
Also, THANKS to this site for all the info.
