Page 4 of 4
Re: 07 WRX TMIC & TD05H-16G installation guide
Posted: Sun Aug 14, 2011 6:00 am
by darkcrave
So basically move the Ftube around and make it fit as best as possible? the TBPS and the coils wires etc. i test fitted the TD05 and it looked like the Intercooling pipe was not even close o.O
Posted: Mon Aug 15, 2011 5:57 pm
by BSOD2600
Yes, move the f-tube so it clears the turbo and intercooler. It doesn't have the stay in the same orientation as OEM -- just as long as the lines go to their correct destinations as OEM.
As stated in the guide, you'll need to modify any Y-tubing you purchase to make it work with any 90* clocked turbo (td04, td05, vf39, etc) and our cars.
Posted: Mon Aug 15, 2011 10:17 pm
by darkcrave
What did you do for the coolant line? it was different then the VF11?
Posted: Tue Aug 16, 2011 4:28 am
by BSOD2600
Coolant lines stayed in the same place.
Posted: Mon Aug 22, 2011 3:19 am
by Guttersmash
Posted: Mon Aug 22, 2011 4:40 am
by legacylok
I just installed that exact same kit, it works way better than the Perrin one I had before.
you really can't beat it for the price. but i would recommend getting a slightly longer piece of straight silicone it makes life alot easier .
Posted: Mon Aug 22, 2011 7:04 pm
by Dominator
I was looking at that y-pipe kit too, and if you have pictures of it installed to share, that would be great. I was thinking about this one, for a GC8 WRX? I found this style on eBay and it looks like the lower leg to the turbo is longer. That might be able to make up the extra length needed instead of the extra set of clamps and the metal pipe.
Ebay Item number: 300381786957
$110.00
Ebay Item number: 120511544072
$65.00
What do you guys think about that?
Posted: Thu Aug 25, 2011 3:01 am
by Guttersmash
legacylok wrote:I just installed that exact same kit, it works way better than the Perrin one I had before.
just got the kit today and I get what you mean by needing a longer piece. When i bolt the 2 pieces on the the 07 topmount they're offset so the short piece of piping won't really work.
Posted: Fri May 03, 2013 4:15 am
by Baddog
What sizes are we talking for the 90 Degree bend and the 2" piece of silicone tubing 2 inch?
Posted: Fri May 03, 2013 3:22 pm
by cj91legss
for the 90 degree bend I think you'll want a 1.75' to 2" reducer. For the 2" piece of silicone, you want 2"........
Posted: Fri May 03, 2013 5:31 pm
by Baddog
I don't see a 1.75" to 2" reducer. I see the 2.5" to the 1.75" thats about it on silicone intakes.
Posted: Fri May 03, 2013 5:36 pm
by cj91legss
Thats only if yoire using the vf11 tho. If youre doing the td05 you dont need the 45 degree bend. Sorry, I should have been more accurate.
You just need the 02-05 y pipe kit and a small piece of 2" pipe. And longer piece of 2" silicone.
Posted: Sun May 12, 2013 6:23 am
by Baddog
Bought a 2.25" 90 degree bend for the TD04. This is for where it connects to the factory intake. This the right size? Talking about the area circled in red off the turbo.
Posted: Sun May 12, 2013 2:32 pm
by cj91legss
yes
Posted: Sat Jun 01, 2013 7:10 pm
by BoostedSubie
I see someone asked before but have not found any info on anyone trying the silicone y pipe for a GC8 wrx. Whether it would be 93-95 or 96-00? I looked up pictures of a 95-96 jdm wrx and it had the slanty intercooler and uses a similar manifold to the EJ22t so the distance of the throttle body and firewall looks to be the same. So, the distance from the turbo outlet and intercooler inlet would be right on but I have never seen a slanty intercooler to see how the y pipe matches up with it. So the question is, would a silicone y pipe meant for a jdm GC8 wrx work with a 06/07 wrx intercooler on an EJ22t with the TD05? I may have to purchase one to find out if no one else has tried it.
Posted: Wed Apr 27, 2016 8:06 pm
by RckyMtnLegacy
Pics stopped working
Posted: Wed May 04, 2016 6:18 pm
I'd suggest trying send the original post an email or PM to see if he still has the pictures.
Posted: Thu May 05, 2016 8:12 pm
by RckyMtnLegacy
Did anyone have any luck with this one? Motor is about to go in and I want to be able to put the intercooler in soon too.
http://www.grimmspeed.com/top-mount-int ... it-subaru/
Posted: Fri May 06, 2016 5:14 am
by mike-tracy
Wtdash and others tried that one. Worked good on the 02-05 tmic, the short silicone piece is horribly kinked on the 06-07. Unless they make an updated one specifically for your tmic i wouldnt bother.
Posted: Fri May 06, 2016 3:30 pm
by RckyMtnLegacy
Ok thanks
Posted: Sat May 07, 2016 5:41 am
RckyMtnLegacy wrote:Pics stopped working
Pics have been fixed.
Posted: Sat May 07, 2016 3:00 pm
by RckyMtnLegacy
Well this is an exciting day!!
Posted: Mon Aug 15, 2016 9:29 am
by theogt
My mount, E85, VF12, Pink STI inj, GT SPEC headler and Prodrive 2.5" exhaust, TMIC WRX 06, new MAP ECU, 4.7V on MAF and 1.18 BAR (17psi), near 200 WHP
