And noticed it has the same up-turned BPV mount as the WRX - that is is the key when buying one as the earlier '04- early '06 FXT's BPV would hit the EJ22T's throttle cables (FXT is DBW so no cables to hit).
Checked on opposedforces.com and sure enough it's the same part number, too.
So, I'm updating my info that the late 2006 to 2008 FXT IC's are the same as the '06-07 WRX IC's and are another option for those installing a TMIC.
Do NOT buy the one like below-note the BPV bolt hole alignment and how it's flush w/the side of the IC:
ALWAYS GET A PIC of what you're buying to ensure it's the newer style!!
TD
