redirecting cooler air to slanty
Posted: Tue Oct 14, 2014 4:16 pm
by turbo970
well i been driving my JDM tdo4 and slanty ic for a couple weeks. drives fine pulls hard. just wondering is theres a way to direct the cooler air to the slanty with the stock scoop
Re: redirecting cooler air to slanty
Posted: Tue Oct 14, 2014 9:57 pm
by SILINC3R
That's about as cool as its going to get unless you go front mount.
Posted: Tue Oct 14, 2014 10:08 pm
by turbo970
i figured that much just wondering how i could kinda aim the air to the slanty more
Posted: Tue Oct 14, 2014 10:34 pm
by SILINC3R
Think it would be to much work. But you could try and get the unslanted WRX intercooler and that might help. Also do you have a turbo blanket and heat shield. If so I wouldn't worry to much unless you just want something to do.
Posted: Tue Oct 14, 2014 11:28 pm
by turbo970
i have a grimmspeed heat sheild. and i was just wondering. i like the slanty because it gives my subie a jdm look. maybe next summer i'll look for a diffrent scoop.
Posted: Wed Oct 15, 2014 12:14 am
by SILINC3R
Yea no worries. Some guys use the RS or WRX scopes for looks and a little more air.
Posted: Wed Oct 15, 2014 12:57 pm
by mike-tracy
You could get the slanty splitter from a GC8, and slot its holes or make a bracket to mount it to our hood. It's not going to be a direct fit by a long shot.
Example:
http://www.ebay.com/itm/400691377803?_t ... EBIDX%3AIT
Posted: Wed Oct 22, 2014 4:00 am
by lucas
I run a slanty IC and i noticed a bigger difference when i went with a WRX hood scoop.
Posted: Sun Oct 26, 2014 12:25 am
by James614
How many people seal the area between the TMIC and hood? Directing air through it and not around it should make a big difference.
Posted: Fri Oct 31, 2014 3:01 am
by bmxpunk
Any one know if the slanty splitter from an early ver1-2 GC would bolt up? I have one on my car but I have a larger Intercooler so I am only feeding air to half of it.
Posted: Fri Oct 31, 2014 2:00 pm
by mike-tracy
The holes.dont line up, but you could prob make it up.
