FS[OH]: 1991 Legacy SS 5MT Rio Red. SOLD
Posted: Wed Sep 07, 2016 12:22 am
Hey Legacy Central,
Throwing up my red Legacy SS. Upfront and forward: This is not a beauty queen. It sat a while and is still waking up a bit, but is running, staying cool, and sounding great. ABS, Cruise and A/C deleted (all wiring and modules present, ABS was converted using non-ABS prop valve). Has rust, but frame/subframes/floors are solid.
If you're still reading, good on you.
Important stuff:
1991 Subaru Legacy SS, 5MT, VLSD, 95k on chassis/drivetrain, 120k on long block. Stock everything.
Eibach Pro lowering springs
OEM struts
ASA 17" wheels
Michelin Exalto A/S (good tread left, but sat a bit)
Newer Exedy clutch
New pads and rotors all around
New plugs
20k on rebuilt original VF11
Original radio and tape player and power antenna all work well.
2.5" catless exhaust
Nardi STi wheel
All electronics work (except sunroof, see below)
Runs and drives pretty well.
The bad:
Steering pump growls a bit and rear wheels rub on hard bumps/turns.
Reverse growls, but never pops out of gear or fails to reverse.
Interior is in good shape, but smells after sitting in the sun.
Sunroof opens manually, but not with the button. Switch works, think the module/motor is dead.
Factory CD player takes a disc, but won't spin/read.
The ugly:
Rust in the rockers, quarters, and lower fenders.
Dings in hood
Front bumper cover is damaged and peeling. Red plastidip sprayed to clean it up a bit. Plastidip done correctly, will peel right off if desired.
Overall, it's been a fun around town car, but need to finish some projects and clear the driveway.
Asking $2200, but very open to offers. Not really interested in trades, but I'll listen.
Car is located in Akron, OH.
You can PM me, email 33092x@gmail.com. Serious buyers will get my cell to call/text.
Thanks!
Important stuff:
OEM struts
ASA 17" wheels
Newer Exedy clutch
New plugs
Nardi STi wheel
The bad:
The ugly:
Dings in hood
Thanks!
