How much of a PITA is the vavle cover gaskets on a 94 SS?
just looking for a rough estimate of time involved....
silly question but can it be done w/o pulling the motor... i know on STI's there is barely enough room in there to do plugs...
-Z
leaking oil, valve cover gaskets?
I recently asked th every same question... My leak was from the passenger side valve cover.
It is an easy job. Do a search for it and you'll find a few helpfull posts, but it is intuitive and quick.
I'd say it took me 1.5hr and a lot of that was spent cleaning up the cover making it all pretty-like before I reassembled. So I have a shinny pass side cover and no more burnt oil smell - yeah!
-Chad
-Chad
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
same deal... I'd remove the washer reservior to gain a bit more clearance, and replace the oil fill neck o-ring while it's apart too.
It's really easy - 3 bolts per valve cover
