i got the rads at the same time! also its two total diffrent motors i used.
my dads answer to much boost!!
so this is the motor ej20g dohc heads and ej22t block with 16g evoIII running 20psi, rad is leaking on drivers side front top "fin bar"
old motor i broke brand new rad koyo as well, ej20k dohc ej22tblock wiseco pistons and aps sr56 running 20psi, broke in the same spot!!
is it cometic head gaskets? is it not having arp head studs? is it the rads where both orderd the same time and they are both no good?
the most funny part about this is, if you guys remmber how i put the last rad in the car i was sure it messed its self up becuse of the way it sat. i take it! it was ok!! and i didnt even need to make the rad sit perfect like stock.
old rad set up that i was sure it broke it i guess not and this borke like the other one same spot!!!
this is how i made the rad sit bye makeing a hole new support and it even use the factory rubbers to hold it in place like it came stock.
brand new out the box, shit i would say 3 - 4 months now of abuse and it leaks same spot? what gives.
back side spray
am i loseing it or did i happen to get two shit rads becuse i order them the same time and becuse it has to happen to me?
