the work was done by me using oem seal/gasket kit. i took my time and used every single piece so nothing was left behind lol. sealed the block, acces hole plugs, oil pump and rear plate with 1215 bond. the front and rear oil seals were seated flush and not pushed in too deep to block oil passages. i see a little fresh oil around the head bolts which im sure is the oil i put on them while installing the heads and also the valve cover gaskets (added oil to those too).
1. is there a way of drop the engine cross member giving me enough room to see where the leak is coming from.
2. also is it safe to run the car for a little bit while its off? seems the oil is only leaking while running. i was thinking of putting some jack stands under the heads to support the engine.
3. compression test were in fsm spec's. 170-180
4. wish i made one of those mini pen camera's lol
if it needs be i'll be taking the engine out again or maybe even the tranny which would be easier? (fwd AT wagon)
any help would be great
btw BIG thanks for the board members and admins for providing information, i wouldnt had done it with out you guys
-Solved- it ended up being the driver side rear cam plug. it was loose so i replaced it with a new one. problem fixed!@!
