Useful EJ22T Engine Part Numbers and Prices
I just looked through the parts manual and price checked a bunch of common engine parts that get replaced in a rebuild. Thought I would share them since it took a while and it might save someone some time.
The crank and cam sensors are crazy expensive. Junkyard FTW!
Price are by each.
Rear Main Seal $8.59 - 806786010
Timing Hole Plug $4.14 - 11413AA032
Flywheel Crank Bolts $0.64 - 800210660 ( x8 )
Cam Seals $8.02 - 806732050 ( x2 )
Cam O Ring $4.23 - 806946030 ( x2 )
Timing Belt $50.36- 13028AA102
Valve Cover Gasket $10.04 - 13294AA011
Oil Filter $4.74 - 15208AA021
Oil Pump $115.16 - 15010AA103
Front Crank Seal $6.17 - 806733010
Water Pump $86.36 - 21111AA021
Water Pump Gasket $2.86 - 21114AA030
Thermostat $11.48 - 21200AA071
Thermostat Gasket $2.47 - 21236AA000
Collant Filler Tank $101.76 - 21132AA010
AC/Alt Belt $10.76 - 809218140
Knock Sensor $59.58 - 22060AA030
Crank Sensor $251.48 - 22053AA010
Cam Sensor $134.83 - 22056AA070
Spark Plugs NGK $2.78 - 22401AA310 ( x4 )
Clutch Fork Shaft $16.24 - 30532AA000
Clutch Fork Shaft Plug $7.97 - 30550AA000
Clutch Fork Shaft Pin $1.44 - 051905320
Total: $915.11 Before tax and shipping.
Here's a list of all these parts in order from above so you can paste them all into 1stsubaruparts.com and then add/remove whichever parts you'd like and change quantities.
806786010,11413AA032,800210660,806732050,806946030,13028AA102,13294AA011,15208AA021,15010AA103,
806733010,21111AA021,21114AA030,21200AA071,21236AA000,21132AA010,809218140,22060AA030,22053AA010,22056AA070,
22401AA310,30532AA000,30550AA000,051905320
EJ22T Hoses and Vacuum Lines + F pipe
Water pump Hoses
807611232
807611242
807615292
Turbo Hoses
807515712
807611202
807519082
807519222
807505482
Intake Manifold Hoses
807607212
807507412
807519202
Fuel Delivery Hoses
807707130
807503172 ( x2 )
807503182
807506081
Engine Cooling System Hoses
807607362
807907032
807611172
807607922
PCV Hoses
807512181
807415102
807519082
807512952
807512962
807512992
807512972
807512982
F Pipe
11821AA320
Emission Control System
807503422
807503452
807505442
807505432
807505452
807204161
skid542
Post by skid542 »
This is awesome. Thank you.
I would like to make the motion that this be stickied.
Lee
Post by SILINC3R »
skid542 wrote:This is awesome. Thank you.
I second this notion
Also, am I wrong to think this works for the N/A EJ22 as well
Some of these parts are the same for the EJ22 NA but some are not. For instance, I believe the water pump is the same but the oil pump is not the same. It has the nipple for the oil cooler on the bottom of the EJ22T. I was told you can plug that nipple though, or just buy the NA one lol.
I think the cam seals may be the same too and the main seals.
I may have missed some parts too that I could add if anyone thinks of them.
PhyrraM
Post by PhyrraM »
Neither the waterpump nor the oil pump are the same between N/A and turbo.
I stand corrected.
Post by SILINC3R »
WEIRD
jaybirde508
Post by jaybirde508 »
Sticky #3
Saskatoon Subaru
Post by Saskatoon Subaru »
why doesn't everyone download the parts catalog and you can find all the parts and part numbers you want.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
You could do that. If you have adobe reader. I just thought it would be nice to have a common rebuild parts numbers thread.
Plus that PDF file is 75MB and some people have dialup still.
Saskatoon Subaru
kimokalihi wrote:You could do that. If you have adobe reader. I just thought it would be nice to have a common rebuild parts numbers thread.
thats just crazy
CFK
Re: Useful EJ22T Engine Part Numbers and Prices
Post by CFK »
Wow this really would of helped me before I just did the same thing last night. Took me hours !
Bump For Sticky :!:
Build Thread : HERE
92 SS 5MT. Project Daily
84 Jetta Coupe. Real Project
99 A4 Avant. Wife's Daily
Someperson
Post by Someperson »
No5 for sticky
93 Winestone TW project
Added to the sticky compilation thread.
CFK
Post by CFK »
Solid Petition, 5 signatures. Bill Passed. A tough Goverment indeed :!: :-D
Build Thread : HERE
Someperson
Thanks!
CFK
Post by CFK »
Does anybody actually know the part #'s of the heater Core Hoses :?:
There is some confusion between the Parts Manual and what comes up on subarugenuineparts.com , so I am confused which one to order. I need Inlet & Outlet heater core hoses for my Turbo 5MT SS Legacy. The manual states that :
72015AA020 - Outlet
72015AA030 - Inlet
72015AA090 - Inlet for MT
On the site it comes up different, Please Help. Thanks :!:
Reid.
Build Thread : HERE
Re:
Saskatoon Subaru wrote:
kimokalihi wrote:Plus that PDF file is 75MB and some people have dialup still.
thats just crazy
You're right, That is definitely crazy.....
CFK
Post by CFK »
Ok, So I received a lightning fast response from SGP.
The correct #'s are :
72015AA020 - Outlet
72015AA030 - Inlet for Automatic
I will confirm when parts are received !
Can anybody do me a favor and send me a VIN # for a 92 5MT SS :?:
As my Canadian VIN will not register in there system, thanks :!:
Build Thread : HERE
