And 2 different vids
Youtube attempt
http://www.youtube.com/watch?v=wR25GQUeP5A
Photobucket attempt
Yours? And what power did you put down?LookAsubie wrote:Mod list? power/fuel mods?
curious so i can kinda compare to my car.
Enough to make one wonder what the MAF reading is at that point.93forestpearl wrote:Your air/fuel bumps down around that point too. The scale on the plot is rather odd.
The small ports in the heads should not have that sharp of change in direction of the power. Power will drop off, but not go from a rising curve instantly to a falling curve. Something else is going on.
rob wrote:No, they used a butt-plug probe and he has a cat. Essentially you can ignore the AFR graph.
I havent had my car dyno'd yet. But my mods are, 3" catless turboback, perrin MBC set at 11-12 ish PSI, stock vf11, 02 wrx intercooler, perrin lightweight crank pulley, short ram intake, wrx BPV and a walbro 255.Florin1 wrote:Yours? And what power did you put down?LookAsubie wrote:Mod list? power/fuel mods?
