td05 - dohc - saab tmic - apexi intake - 2.5" exhaust
as you all know my car is rwd and i actuality drift it and as you know drifting is a lot of 100% throttle and revlimiter
i know i need bigger injectors and some sort of tunning
this has happened to me twice now in two different blocks
both times in the same cylinder (#4 drivers side back cylinder) and on the top of the piston
so im thinking i might have a bad injector so ive dropped them off to get flow tested and cleaned and he is going to try and bumped them up past 370 if he can
but if all the injectors come back good then what is causing this, because #4 is the 1st one to get fuel.
