TD05 16G Coolant Line Modifications
LookAsubie
Post by LookAsubie »
I just picked up some sti yellowtop injectors today :) and I'm getting rails from a friend, all I need is some cooland lines for the turbo, a tuned ecu and ignition converter from you, and put all my stuff in. Can't wait!!
1992 legacy SS 5mt, Winestone Metallic.
Florin1
Re: Rob's 4to2 Igntion Converter
Post by Florin1 »
^I got a vf11 sitting. I dont know what kind of turbo you have, but my coolant lines will prob fit if ur interested
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
wtdash
Post by wtdash »
Florin1 wrote:^I got a vf11 sitting. I dont know what kind of turbo you have, but my coolant lines will prob fit if ur interested
His is a TD05 and they won't work stock.
Edit: The TD05 uses bigger bolts (?) for the coolant lines on the turbo. I 'think' somebody on here posted that info.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
I did it. Josh did it. If you ask josh he's got the info you need and pictures I think.
You know me too well ;)
Pictures for the coolant line mod is at the bottom of the first page and top of second.
http://www.main.experiencetherave.com/s ... es/td05/01
LookAsubie
Thanks todd,
And yeah if one of you could let me know or post pictures of exactly what i need to get that would be awesome!
LookAsubie
Re: TD05 16G Coolant Line Modifications
Josh do you have the part numbers for the correct size bolts and where I might be able to find them?
And i just use that step bit to open up the stock lines a little more until they fit?
The bolts I used came with the turbo, so I don't have any specific info about them. Baker Precision is where I got some of the fittings for my custom clutch line. They may have bolts that work. http://www.bakerprecision.com/
Yup, just use the step bit to open the holes up until the bolt fits through. I'd recommend getting the bolts before you go and open the stock lines up.
