Good afternoon,
I figured some of you would like some info on how about getting this done; machining the block to accept the number 5 thrust bearing.
Bearing Service Co. in Portland, OR managed to do this (they actually have done it before). I had them do all my machine work on my EJ22T.
Just for the thrust cut ran me $245 bucks. It was the only place I could find that would/try to do it.
The bearings are STI EJ257 ACL Race, the number 5 thrust bearing is around 1MM wider than the stock EJ22T number 3 thrust bearing.
Here are some pic:
The chewed up end is from were the flex plate broke and rubbed up against the block.
Mock assembling the engine to check for clearances
I am using a 2011 STI crank.
EJ22T NUMBER 5 THRUST BEARING.
91 black SS 5 speed (Canadian).... Closed deck EJ20G, fully built, V5/6 sti ra drivetrain, haltech stand-alone
93 silver TW 5 speed... rebuilt 22T with 20G heads, wrx ra drivetrain, otherwise stock.
73 kazen red VW bus riviera camper
Re: EJ22T NUMBER 5 THRUST BEARING.
Nice!
Thanks for the pics. I am gonna have to find someone around here that can do it for my build....
Rio Red '91 Legacy SS
Nice build! How long has it lasted (in miles) and at what boost level and fuel?
