In essence this build completely eliminates the viscous type center diff and replaces it with a manual locking center diff (open or 50/50)
Parts needed:
Ej 5mt of your liking (I used a 03 forester 5mt)
Complete Subaru rx or xt6 dual range all time awd 5mt
From the factory Subaru used a very unique transmission in the Rx/xt6. It was a dual range, all time awd 5 speed with center diff locker. Basically it was the pre-curser 5mt to the standard 5mt used in everything 1990+ and because of this a lot of things are interchangeable between the Rx/xt6 5mt and the ej based 5mt..
So here is were it gets a little tricky.
Basically you need to have both trans apart and next to each other. With both cases split you need to transfer the front ring and pinion from the Rx transmission into the ej transmission. Both are easy to get at and to save work swap just the ring gear itself onto the ej front diff (same for doing rear vlsd swap). Basically you want to keep bearings matched up so you don't have to mess with setting pre load and having to jack with backlash and adjusting bearings and gears. Once ring gear is swapped you need to swap the pinion into the driven gear set of the ej trans. This again is super easy. One big nut on the end of the pinion and the whole thing slips out. BE CAREFUL TO KEEP BEARINGS WITH THE PINION! the rx /xt pinion is about 6" longer and is required to make the center diff locker work.. Once your Rx pinion is torqued to spec and the nut has been peened you can set the driven gear set back into the ej case and re assemble.. You will now have this (notice phase 2 case with Rx pinion sticking out the back)
And a regular ej trans for pinion comparrison
From here you simply slide the Rx tail shaft housing (transfer box with center diff) onto the back of the ej transmission. And you end up with this:
See the little lever on the side? That's the diff lock actuator, on the Rx this was hooked to a vacuum can that had two sides so it could push or pull. I managed to salvage the actuator can (tucks under starter) and used some random vacuum solenoids to control it...
A pic of the locker piece itself:
Some other notes:
The diff locker center is 2.5" shorter then a viscous center (requires 2.5" longer drive shaft)
Requires custom shift linkage
Requires custom trans mount
Enjoy!
