Just a quick question will the Impreza clutch hose 1992-2000 part be a direct swop for my 1992 Legacy Turbo?
I think I read somewhere the vehicle part were the same? Mine in RHD in England etc.
Also the slave cylinder agin Ok to use the Impreza unit?
Comments welcomed.
1992 Legacy Turbo Clutch parts OK to use Impreza parts?
Re: 1992 Legacy Turbo Clutch parts OK to use Impreza parts?
If they are both turbo pull-type clutbes it should all work, In the us all the 92-00 (my 93-01 here) Imprezas were non turbo and push type cluthes, some even cable operated.
Thanks for the info, now ordered.
Update impreza parts went on without issue.
