onur wrote:Thanks. FYI.
EBC YellowStuff
Fronts part# is E35DP4966R.
Rears part# E35DP4821R
Anyone else has part#s from different manufacturers? please post them up. this could be a good thread.
I'm bored:
Description Price Details
BRAKE LINING/FRICTION, FRONT
ABSCO D563IH SEMI-METALLIC BRAKE PAD W/SHIM
Note: front pads; turbo *
ACDELCO DURASTOP BRAKES 17D563 ORGANIC BRAKE PAD
Note: front; 15" whls; oe organic; recommended replacement 55.86
ATE/PREMIUMONE AT470 PREMIUMONE BRAKE PAD
Note: front; 14" whls *
AIMCO PF563 PREMIUM ORGANIC BRAKE PAD
Note: front; 15" whls; oe organic; recommended replacement 45.86
AIMCO SPF563 SUPER PREMIUM ORGANIC BRAKE PAD
Note: front; 15" whls; oe organic; recommended replacement 50.39
AISIN WORLD CORP. OF AMERICA AD0563 BRAKE PADS
Note: front *
AKEBONO ACT470 BRAKE PAD
Note: front; ceramic; 14" whls-proact ultra premium ceramic pad 88.10
AKEBONO ACT563 BRAKE PAD
Note: front; ceramic; 15" whls-proact ultra premium ceramic pad 104.65
AKEBONO ISD563 BRAKE PAD
Note: front; ceramic; 15" whls-premium ceramic pads 95.90
AUTOPRIDE PRIVATE LABELS SCP563 CERAMIC BRAKE PAD
Note: front; oe ceramic; turbo *
AUTOPRIDE PRIVATE LABELS MD563 FRONT PREMIUM SEMI-METALLIC PADS *
AUTOPART INTERNATIONAL 1412-37098 PADS
Note: front pmct ceramic; w/4wd turbo; oe material is ceramic 110.12
AUTOPART INTERNATIONAL 1401-52854 PADS
Note: front premium organic; w/4wd turbo *
AUTOPART INTERNATIONAL 1402-69487 PADS
Note: front ultra; w/4wd turbo 41.70
AUTOPART INTERNATIONAL 1403-85487 PADS
Note: front posi-met; w/4wd turbo 68.32
AUTOPARTSOURCE CE563 CERAMIC PADS
Note: front; oe ceramic; turbo 78.74
AMERICAN REMANUFACTURING INC. 62-D563 ROAD PROVEN INTEGRALLY MOLDED METALLIC (PMQ) PADS
Note: 4wd; front 49.31
AMERICAN REMANUFACTURING INC. 63-D563 FRONT PADS
Note: 4wd; front 39.07
AMERICAN REMANUFACTURING INC. 65-D563 AXXIS METALMASTER PADS
Note: 4wd; front 59.96
AMERICAN REMANUFACTURING INC. 66-D563 AXXIS DELUXE NAO PADS
Note: 4wd; front 46.96
AMERICAN REMANUFACTURING INC. 68-D563 ROADPROVEN CERAMIC PADS
Note: 4wd; front 83.44
AUTOSTAR PRIVATE LABELS CP470 CERAMIC BRAKE PAD
Note: front; w/14" whls, to 5/96 76.80
AUTOSTAR PRIVATE LABELS D470 ORGANIC BRAKE PAD
Note: front; w/14" whls, to 5/96 29.20
AUTOSTAR PRIVATE LABELS D563 ORGANIC BRAKE PAD
Note: front; w/15" whls, to 5/96 36.78
AUTOSTAR PRIVATE LABELS DS470 ORGANIC SHIMMED BRAKE PAD
Note: front; w/14" whls, to 5/96 *
AUTOSTAR PRIVATE LABELS MD470 SEMI-METALLIC BRAKE PAD
Note: front; w/14" whls, to 5/96 31.26
AUTOSTAR PRIVATE LABELS MDS470 SEMI-METALLIC SHIMMED BRAKE PAD
Note: front; w/14" whls, to 5/96 44.20
AUTOSPECIALTY 23-563-01 HD PAD FRONT 87.80
AUTOSPECIALTY 25-563-01 BRAKE PAD FRONT 53.42
AUTOTEC1 AD563 BRAKE PADS
Note: frt.; plate # *
AUTO EXTRA FRICTION AXMD470 PREMIUM METALLIC DISC BRAKE PADS
Note: front; w/14" whls-plain rear discs; w/shims *
AUTO EXTRA FRICTION AXCD470 CERAMIC ENHANCED METALLIC DISC PADS
Note: front; w/14" whls-plain rear discs *
AUTO EXTRA FRICTION AXMD563 PREMIUM METALLIC DISC BRAKE PADS
Note: front; w/15" whls-vented rear discs; w/shims *
AUTO EXTRA FRICTION AXCD563 CERAMIC ENHANCED METALLIC DISC PADS
Note: front; w/15" whls-vented rear discs *
AUTO EXTRA FRICTION AXOD470 ORGANIC DISC BRAKE PADS
BECK/ARNLEY 082-1490 BRAKE PADS, PREMIUM ORGANIC
Note: oe pad material; replace oe semi-met w/semi-met only 54.11
BECK/ARNLEY 088-1490D BRAKE PADS, AXXIS ORGANIC
Note: oe pad material; replace oe semi-met w/semi-met only 65.54
BENDIX D470 CQ CERAMIC BRAKE PAD
Note: front; oe ceramic; 14" whls *
BENDIX D470CT CT CERAMIC BRAKE PAD
Note: front; oe ceramic; 14" whls 89.69
BENDIX MKD470 SEMI-METALLIC BRAKE PAD
Note: front; 14" whls 68.38
BENDIX MKD470IQ IMPORT QUIET BRAKE PAD
BENDIX MKD563 SEMI-METALLIC BRAKE PAD
Note: front; 15" whls 68.76
BENDIX MRD470 GLOBAL SEMI-METALLIC BRAKE PAD
BENDIX MRD563 GLOBAL SEMI-METALLIC BRAKE PAD
Note: front; 15" whls *
BRAKE BEST D470 BRAKE PAD
Note: front; organic; w/14" whls *
BRAKE BEST MKD470 BRAKE PAD
Note: front; semi-met; w/14" whls *
BRAKE BEST MKD563 BRAKE PAD
Note: front; semi-met; w/15" whls *
BENDIX GLOBAL MRD470 SEMI-METALLIC BRAKE PAD
BENDIX GLOBAL MRD563 SEMI-METALLIC BRAKE PAD
CARQUEST BD563 BRAKE PAD
Note: front; blue nao; organic premium pad; oe w/organic material; recommended replacement, 15" whls 63.62
CARQUEST GSD563 BRAKE PAD
Note: front; global solution; semi-met premium plus pad; oe w/organic material; 15" whls 67.18
CENTRIC PARTS 108.05630 AXXIS METAL MASTER BRAKE PADS
Note: front; 4wd turbo *
CENTRIC PARTS 105.04700 POSI-QUIET CERAMIC BRAKE PADS W/SHIMS
Note: front; recommended friction; wagon;, w/o abs *
Note: front; recommended friction, sdn;, w/o abs *
CENTRIC PARTS 105.05630 POSI-QUIET CERAMIC BRAKE PADS W/SHIMS
Note: front; recommended friction; wagon; 4wd *
Note: front; recommended friction, sdn; 4wd *
CENTRIC PARTS 107.04700 AXXIS DELUXE PLUS PADS
Note: front; wagon;, w/o abs *
Note: front, sdn;, w/o abs *
CENTRIC PARTS 107.05630 AXXIS DELUXE PLUS PADS
Note: front; wagon; 4wd *
CENTRIC PARTS 100.05630 OEM FORMULA
CENTRIC PARTS 300.04700 CENTRIC PREMIUM BRAKE PADS
CENTRIC PARTS 102.04700 C-TEK STD METALLIC PADS
CENTRIC PARTS 102.05630 C-TEK STD METALLIC PADS
CENTRIC PARTS 106.04700 POSI-QUIET EXTENDED WEAR PADS W/SHIMS
CENTRIC PARTS 106.05630 POSI-QUIET EXTENDED WEAR PADS W/SHIMS
CENTRIC PARTS 100.04700 OEM FORMULA
Note: front, sdn; 4wd *
CONI-SEAL SCP563 CERAMIC BRAKE PAD
CARLSON QUALITY BRAKE PARTS D563 BRAKE PAD
Note: front; legacy listing *
DURA INTERNATIONAL D470 BRAKE PAD
Note: front; disc *
Note: front; drum *
FEDERATED BRAKES D563 ORGANIC PREMIUM BRAKE PAD
Note: front front; 15" whls; oe organic; recommended replacement *
FEDERATED BRAKES MD563 SEMI METALLIC PREMIUM BRAKE PAD
Note: front front; 15" whls; oe organic *
FRICTION MASTER D470 ORGANIC BRAKE PAD
Note: front; w/14" whls *
FRICTION MASTER MKD470 SEMI-METALLIC BRAKE PAD
FRICTION MASTER MX470 PREMIUM SEMI-METALLIC BRAKE PAD
Note: front; oe recommended material; w/14" whls *
FRICTION MASTER CMX470 CERAMIC BRAKE PAD
FRICTION MASTER MKD563 SEMI-METALLIC BRAKE PAD
Note: front; w/15" whls *
FRICTION MASTER MX563 PREMIUM SEMI-METALLIC BRAKE PAD
Note: front; oe recommended material; w/15" whls *
GUARDIAN BRAKE PRODUCTS 65-563 BRAKE PADS
Note: front; w/15" whl *
GUARDIAN RETAIL 61-7442 FRONT BRAKE PAD-ORGANIC
Note: 4x4; recommended oem rpl *
GUARDIAN RETAIL 65-7442 FRONT SEMI-METALLIC PAD
Note: 4x4 *
HAMPDEN AUTOMOTIVE HDD-470 BRAKE PADS
Note: w/14" wheels; heavy duty set 69.90
HAMPDEN AUTOMOTIVE MD-470 BRAKE PADS
Note: w/14" wheels; front set 62.00
HAMPDEN AUTOMOTIVE MD-563 BRAKE PADS
Note: w/15" wheels; front set 56.00
HAMPDEN AUTOMOTIVE HDD-563 BRAKE PADS
Note: w/15" wheels; heavy duty set 66.30
INWOOD DMX470 DISC BRAKE PAD
Note: front; intimidator; w/14" whls *
INWOOD DMX563 DISC BRAKE PAD
Note: front; intimidator; w/15" whls *
INWOOD PDMX470 DISC BRAKE PAD
Note: front; intimidator plus professional grade; w/14" whls *
INWOOD PDMX563 DISC BRAKE PAD
Note: front; intimidator plus professional grade; w/15" whls *
INWOOD M470 DISC BRAKE PAD
Note: front; prem semi met pads; w/14" whls {superceded by dmx470} *
INWOOD M563 DISC BRAKE PAD
Note: front; prem semi met pads; w/15" whls {superceded by dmx563} *
INWOOD S470 DISC BRAKE PAD
Note: front; superiorone plus; w/14" whls *
INWOOD SP470 DISC BRAKE PAD
Note: front; spectraone plus; w/14" whls *
INWOOD SPQ470 DISC BRAKE PAD
Note: front; ultraquiet; w/14" whls *
KEMPARTS D563 PERFECT VALUE NAO PADS
Note: front; 15" wheel 41.31
KEMPARTS XD563 FRICTION PRO NAO/LOW-MET PADS
Note: front; 15" wheel; oe recommended 57.99
MINTEX MDB1496 BRAKE PAD
Note: front; awd *
Note: front; sumitomo; awd *
MEVOTECH INC. MM7442 FRONT SEMI-METALLIC PAD
MEVOTECH INC. MT7442 FRONT SEMI-MET PAD-PREMIUM
MIGHTY MD470K OPTIONAL UPGRADE
Note: f *
MIGHTY D311 PAD/SHOE - OE REPLACEMENT
Note: front *
MIGHTY MD470 PAD/SHOE - OE REPLACEMENT
Note: front; exc 4x4 turbo *
MORSE FMKD470 FRONT SEMI-MET PAD-PREMIUM
Note: 4x4; recommended oe rpl; rpl oe met pads w/met pads; failure to may void warranty & product liability; w/14" whls *
MORSE MKD470 DISC PAD
Note: frt.; pr.; w/14 in. whl. *
MORSE MKD563 DISC PAD
Note: frt.; pr.; w/15 in. whl. *
MORSE FD470 FRONT BRAKE PAD-PREMIUM
Note: 4x4; w/14" whls *
MORSE FMKD563 FRONT SEMI-MET PAD-PREMIUM
Note: 4x4; recommended oe rpl; rpl oe met pads w/met pads; failure to may void warranty & product liability; w/15" whls *
MONROE PREMIUM BRAKE PADS CX563 PREMIUM CERAMIC BRAKE PADS
Note: front; awd; sdn & wagon; w/turbo eng; oe replacement recommendation *
MONROE PREMIUM BRAKE PADS DX563 DYNAMIC BRAKE PADS
Note: front; awd; sdn & wagon; w/turbo eng *
NEW JERSEY AMERICAN MD563 FRONT PREMIUM SEMI-METALLIC PADS *
NU-GEON 45-04700D AXXIS DELUXE ORGANIC
Note: front; exc 4wd turbo 59.04
NU-GEON 45-04700M AXXIS XBG SEMI-METALLIC
Note: front; exc 4wd turbo; recommended oe replacement 74.70
NU-GEON 45-05630D AXXIS DELUXE
Note: front; 4wd turbo; recommended oe replacement 65.97
NEWTEK AUTOMOTIVE CRD470-7350 ADVANCED CERAMIC DISC PADS-POSITIVE MOLDED
NEWTEK AUTOMOTIVE CRD563-7442 ADVANCED CERAMIC DISC PADS-POSITIVE MOLDED
NEWTEK AUTOMOTIVE IMD470-7350 PREMIUM METALLIC DISC BRAKE PADS
NEWTEK AUTOMOTIVE IMD563-7442 PREMIUM METALLIC DISC BRAKE PADS
NEWTEK AUTOMOTIVE SMXD470-7350 CERAMIC ENHANCED METALLIC DISC PADS
NEWTEK AUTOMOTIVE SMXD563-7442 CERAMIC ENHANCED METALLIC DISC PADS
PARTS DEPOT PREFERRED D470 ORGANIC BRAKE PAD
PARTS DEPOT PREFERRED MKD470 SEMI-METALLIC BRAKE PAD
PARTS DEPOT PREFERRED MX470 PREMIUM SEMI-METALLIC BRAKE PAD
PARTS DEPOT PREFERRED CMX470 CERAMIC BRAKE PAD
PARTS DEPOT PREFERRED MKD563 SEMI-METALLIC BRAKE PAD
PARTS DEPOT PREFERRED MX563 PREMIUM SEMI-METALLIC BRAKE PAD
PARTS MASTER/MORSE D470 BRAKE PAD
Note: front; d; w/14" whls *
PARTS MASTER/MORSE MD470 BRAKE PAD
Note: front; md; w/14" whls *
PARTS MASTER/MORSE MKD470S BRAKE PAD
Note: front; mkd; oe recommended material; w/14" whls *
PARTS MASTER/MORSE CMX470 BRAKE PAD
Note: front; cmx; w/14" whls *
PARTS MASTER/MORSE MD563 BRAKE PAD
Note: front; md; w/15" whls *
PARTS MASTER/MORSE MKD563S BRAKE PAD
Note: front; mkd; oe recommended material; w/15" whls *
PARTS MASTER FMKD470 FRONT SEMI-MET PAD-PREMIUM
PARTS MASTER MKD470 DISC PAD
PARTS MASTER MKD563 DISC PAD
PARTS MASTER FD470 FRONT BRAKE PAD-PREMIUM
PARTS MASTER FMKD563 FRONT SEMI-MET PAD-PREMIUM
PARTS MASTER D563 FRONT BRAKE PAD-ORGANIC
PARTS MASTER D7442 FRONT BRAKE PAD-ORGANIC
PARTS MASTER MD563 FRONT SEMI-METALLIC PAD
Note: 4x4 *
PARTS MASTER MD7442 FRONT SEMI-METALLIC PAD
Note: 4x4 *
PRENCO 9C-7442 FRONT BRAKE PAD-PREMIUM
Note: 1 per veh; 4x4; w/vent. rr. discs, 15" whls. or tur; *
PRENCO 9C-7350 FRONT BRAKE PAD-PREMIUM
Note: 1 per veh; 4x4; w/rr. discs, 260 mm. fr. discs; *
PRONTO SCP563 CERAMIC BRAKE PAD
PRONTO PAD563 BRAKE PADS
Note: frt.; lining # *
PRONTO PS563 BRAKE PADS
PARTS PLUS BLUE FRICTION PPB563 ORGANIC BRAKE PAD
Note: front; 15" whls, oe organic *
POWER STOP 16-470 Z16 CLEAN RIDE CERAMIC BRAKE PADS
Note: front; oe ceramic; 14" whls; to 5/96 *
POWER STOP 16-563 Z16 CLEAN RIDE CERAMIC BRAKE PADS
Note: front; oe ceramic; 15" whls; to 5/96 *
CARQUEST/RAYBESTOS BD563 ORGANIC PREMIUM BRAKE PAD
Note: front; 15" whls; oe organic; recommended replacement 63.62
CARQUEST/RAYBESTOS GSD563 SEMI METALLIC PREMIUMPLUS BRAKE PAD
Note: front; 15" whls; oe organic; sell-out do not reorder 67.18
CARQUEST/RAYBESTOS RD563 ORGANIC STANDARD BRAKE PAD
Note: front; 15" whls; oe organic *
QUALITEE INTERNATIONAL CE470 FRONT PADS VGX CERAMIC
Note: sdn, exc 4wd; wagon; w/14" whls 78.74
QUALITEE INTERNATIONAL CE563 FRONT PADS VGX CERAMIC
Note: sdn, exc 4wd; wagon; w/15" whls 78.74
QUALITEE INTERNATIONAL MF470 FRONT PADS VGX STEALTH
Note: sdn, exc 4wd; wagon; w/14" whls 66.56
QUALITEE INTERNATIONAL MF470K1 FRONT PADS VGX CLAMSHELL
Note: sdn, exc 4wd; wagon; w/14" whls 91.85
QUALITEE INTERNATIONAL MF563 FRONT PADS VGX STEALTH
Note: 4wd, sdn 65.89
QUALITEE INTERNATIONAL MF563K FRONT PADS VGX CLAMSHELL
Note: 4wd, sdn 93.50
QUALITEE INTERNATIONAL PF470 FRONT PADS PERFORMANCE PLUS ORGANIC
Note: sdn, exc 4wd; wagon; w/14" whls 43.89
QUALITEE INTERNATIONAL PF563 FRONT PADS PERFORMANCE PLUS ORGANIC
Note: 4wd, sdn 41.58
QUALITEE INTERNATIONAL PFM470 FRONT PADS PERFORMANCE PLUS SEMI-METALLIC
Note: sdn, exc 4wd; wagon; w/14" whls 48.28
RAYBESTOS PGD563 PROFESSIONAL GRADE ORGANIC BRAKE PAD
Note: front; 15" whls; oe organic; recommended replacement 63.33
RAYBESTOS PGD563C PROFESSIONAL GRADE CERAMIC BRAKE PAD
Note: front; 15" whls; oe organic 81.43
RAYBESTOS PGD563M PROFESSIONAL GRADE SEMI METALLIC BRAKE PAD
Note: front; 15" whls; oe organic 71.91
RAYBESTOS SGD563C SERVICE GRADE CERAMIC BRAKE PAD
REMSA OF AMERICA GMKD470 GOLD PREMIUM SEMI MET PADS W/SHIMS
REMSA OF AMERICA IAD563 GOLD PREMIUM NAO PADS W/SHIMS
REMSA OF AMERICA ICD470 GOLD PREMIUM CERAMIC PADS W/SHIMS
REMSA OF AMERICA MKD470 SILVER SEMI METALLIC PADS W/O SHIMS
REMSA OF AMERICA MKD563 SILVER SEMI METALLIC PADS W/O SHIMS
REPLEX AUTOMOTIVE D470 DISC BRAKE PAD
Note: front; w/14" wheel solid rear disc; fmsi: 7350 *
REPLEX AUTOMOTIVE D563 DISC BRAKE PAD
Note: front; w/15" wheel vented rear disc; fmsi: 7442 *
AUTOSTAR PREMIUM DISC PADS D563 PREMIUM ORGANIC BRAKE PAD
AUTOSTAR PLATINUM DISC PADS DS563 PLATINUM ORGANIC BRAKE PAD
SATISFIED BRAKE PRODUCTS PR563 PRO SERIES PERFORMANCE BRAKE PAD
Note: front; recommended replacement part# for this application *
SATISFIED BRAKE PRODUCTS CL563 PRO SERIES CLASSIC BRAKE PAD
Note: front *
SATISFIED BRAKE PRODUCTS MPD563 ULTRA SERIES BRAKE PAD
Note: front *
SATISFIED BRAKE PRODUCTS PD563 NON-ASBESTOS ORGANIC BRAKE PAD
Note: front *
USI/AUTO EXTRA AXMD563 PG PLUS PREMIUM SEMI-METALLIC BRAKE PAD
STEWART RIDDLE CRD563 VORTEX CERAMIC OE REPLACEMENTOE REPLACEMENT BRAKE PAD
Note: front; turbo *
STEWART RIDDLE D563 BASE NUMBER BRAKE PAD
STEWART RIDDLE VSD563 VORTEX SUPER PREMIUM POSITIVE MOLDED BRAKE PAD
STEWART RIDDLE XMD563 ECONOMY SEMI-METALLIC BRAKE PAD
STEWART RIDDLE XXD563 ECONOMY NON-ASBESTOS ORGANIC BRAKE PAD
STEWART RIDDLE SPD563 APPLICATION SPECIFIC WITHOUT SHIMS BRAKE PAD
STEWART RIDDLE SQD563 APPLICATION SPECIFIC WITH SHIMS BRAKE PAD
TRUST DISC PADS D563 ORGANIC BRAKE PAD
MINTEX BRAKES-TMD FRICTION MDB1688 BRAKE PAD
Note: front; sdn; 4wd turbo *
MINTEX BRAKES-TMD FRICTION MDB1688X MINTEX PADS XTREME
Note: front; wagon; 4wd turbo *
TRUST AFD563 FRONT ASBESTOS-FREE PAD
Note: 4x4; from 2/92 *
TRUSTAR PPM563 CERAMIC BRAKE PAD
UNIVERSAL BRAKE PARTS CP470 CERAMIC BRAKE PAD
Note: front; w/14" whls, to 5/96 78.00
UNIVERSAL BRAKE PARTS D470 ORGANIC BRAKE PAD
Note: front; w/14" whls, to 5/96 35.98
UNIVERSAL BRAKE PARTS D563 ORGANIC BRAKE PAD
Note: front; w/15" whls, to 5/96 39.80
UNIVERSAL BRAKE PARTS DS470 ORGANIC SHIMMED BRAKE PAD
Note: front; w/14" whls, to 5/96 55.50
UNIVERSAL BRAKE PARTS MD470 SEMI-METALLIC BRAKE PAD
Note: front; w/14" whls, to 5/96 36.26
UNIVERSAL BRAKE PARTS MDS470 SEMI-METALLIC SHIMMED BRAKE PAD
Note: front; w/14" whls, to 5/96 59.24
WAGNER ZX563 QUICKSTOP BRAKE PADS
Note: front; w/15" whl 53.48
WAGNER MX563 THERMOQUIET BRAKE PADS
Note: front; w/15" whl 79.02
WORLD BRAKE CMX563 PREMIUM CERAMIC BRAKE PAD
Note: front *
WORLD BRAKE MD563 SEMI-METALLIC BRAKE PAD
Note: front *
WORLD BRAKE SMX563 CERAMIC ENHANCED SEMI-METALLIC BRAKE PAD
Note: front *
WORLD BRAKE SP563 POSITIVE MOLD PREMIUM SEMI-METALLIC BRAKE PAD
Note: front *
WORLD BRAKE VD563 POSITIVE MOLD HIGH PERF SEMI-METALLIC BRAKE PAD
Note: front *
WAGNER CATEGORICAL NUMBERS ZX563 QUICKSTOP BRAKE PADS
WAGNER CATEGORICAL NUMBERS MX563 THERMOQUIET BRAKE PADS
EUROROTOR ID470 F1 ICE BRAKE PADS
EUROROTOR MMD470 METALLIC MOLDED BRAKE PADS
EUROROTOR MMD563 METALLIC MOLDED BRAKE PADS
AUTOZONE/DURALAST MKD470 BRAKE PAD
Note: front semi-met; w/14" whls; consistent & effective braking; w/shims incld where applicable *
AUTOZONE/DURALAST MKD563 BRAKE PAD
Note: front semi-met; w/15" whls; consistent & effective braking; w/shims incld where applicable *
AUTOZONE/MIDAS BP1490C Z-MIDAS BRAKE PAD/SHOE - FRONT
Note: with 2 wheel drive; with 14" wheels with shim; ceramic pad *
AUTOZONE/MIDAS BP1490M Z-MIDAS BRAKE PAD/SHOE - FRONT
Note: with 2 wheel drive; with 14" wheels with shim; metallic pad *
AUTOZONE/MIDAS BP1602M Z-MIDAS BRAKE PAD/SHOE - FRONT
Note: with 4 wheel drive; with shim; metallic pad *
Note: with 2 wheel drive; with 15" wheels with shim; metallic pad *
AUTOZONE/VALUECRAFT MKD470V BRAKE PADS
Note: front semi-met; smooth, quiet stopping *
FRONT BRAKE PAD SHIMS
AUTOSPECIALTY SH-1363 PAD SHIM KIT FRONT 12.38
BECK/ARNLEY 084-2117 DISC PAD SHIM KIT
Note: front; steel shim; steel shim with self-adhesive backing. 11.34
BETTER BRAKE PARTS 8801 DISC PAD SHIM KIT
Note: front; 15" whls; turbo; sedan; awd *
CARLSON QUALITY BRAKE PARTS 18031 DISC BRAKE PAD SHIM KIT
Note: front; fmsi pad/shoe ref# d470 9.24
CARLSON QUALITY BRAKE PARTS 18037 DISC BRAKE PAD SHIM KIT
Note: front; 4dr (4wd); fmsi pad/shoe ref# d563 9.24
FEDERATED BRAKES DS8031 BRAKE PAD SHIMS
Note: frt.; 14" whl. *
FEDERATED BRAKES DS8037 BRAKE PAD SHIMS
Note: frt.; 15" whl. *
MIGHTY 18031 SHIMS
MIGHTY 18013 SHIMS
Note: front *
PARTS PLUS BRAKE HARDWARE P8801 DISC PAD SHIM KIT
RAYBESTOS DS8037 PG PLUS BRAKE PAD SHIM
Note: front; 15" whls 12.85
REMSA OF AMERICA S276 BRAKE PAD SHIM SET
Note: prem.; frt.; std. duty; legacy list. *
SATISFIED BRAKE PRODUCTS STM124K SHIM
Note: frt.; legacy awd turbo fr. 2/92 12.11
WAGNER PQ300112 FRONT PAD SHIM KIT
Note: 4x4 5.90
WAGNER SH1108-7 SHIM
Note: frt. 11.20
WAGNER CATEGORICAL NUMBERS SH1108-7 SHIM
Note: frt. 11.20
BRAKE LINING/FRICTION, REAR
ABSCO D471IH ORGANIC BRAKE PAD
Note: rear pads; turbo *
ABSCO D471OR ORGANIC BRAKE PAD
ACDELCO DURASTOP BRAKES 17D471 ORGANIC BRAKE PAD
Note: rear; 15" whls; oe organic; recommended replacement 57.04
ACDELCO DURASTOP BRAKES 17D471C CERAMIC BRAKE PAD
Note: rear; 15" whls; oe organic 67.21
ACDELCO DURASTOP BRAKES 17D471M SEMI METALLIC BRAKE PAD
Note: rear; 15" whls; oe organic 85.60
ATE/PREMIUMONE AT471 PREMIUMONE BRAKE PAD
Note: rear; 15" whls; to 2/92 *
Note: rear; 14" whls; from 3/92 *
Note: rear; 14" whls; to 2/92 *
Note: rear; 15" whls; from 3/92 *
AIMCO PF471 PREMIUM ORGANIC BRAKE PAD
Note: rear; 15" whls; oe organic; recommended replacement 42.04
AIMCO SPC471S EXTREME SERVICE CERAMIC BRAKE PAD
Note: rear; 15" whls; oe organic 113.19
AIMCO SPF471 SUPER PREMIUM ORGANIC BRAKE PAD
Note: rear; 15" whls; oe organic; recommended replacement 51.37
AIMCO SPM471 SUPER PREMIUM SEMI METALLIC BRAKE PAD
Note: rear; 15" whls; oe organic 78.04
AISIN WORLD CORP. OF AMERICA AD0471 BRAKE PADS
Note: rear *
AKEBONO ACT471 BRAKE PAD
Note: rear; ceramic; 14" whls-proact ultra premium ceramic pad 102.10
Note: rear; ceramic; 15" whls-proact ultra premium ceramic pad 102.10
AKEBONO ASP471 BRAKE PAD
Note: rear; ceramic; 14" whls-street perf ultra premium ceramic pad 109.00
Note: rear; ceramic; 15" whls-street perf ultra premium ceramic pad 109.00
AUTOPRIDE PRIVATE LABELS SCP471 CERAMIC BRAKE PAD
Note: rear; oe ceramic; turbo *
AUTOPRIDE PRIVATE LABELS SMP471 PREMIUM METALLIC BRAKE PAD
Note: rear; turbo *
AUTOPRIDE PRIVATE LABELS SSD471 REAR SEVERE DUTY PADS
Note: titanium ti22 *
AUTOPRIDE PRIVATE LABELS MD471 REAR PREMIUM SEMI-METALLIC PADS *
AUTOPART INTERNATIONAL 1412-36416 PADS
Note: rear pmct ceramic; w/4wd turbo; oe material is ceramic 109.24
AUTOPART INTERNATIONAL 1401-53117 PADS
Note: rear premium organic; w/4wd turbo *
AUTOPART INTERNATIONAL 1402-69417 PADS
Note: rear ultra; w/4wd turbo 41.70
AUTOPART INTERNATIONAL 1403-86117 PADS
Note: rear posi-met; w/4wd turbo 64.90
AUTOPARTSOURCE MF471K SEMI-METALLIC PAD KIT W/HARDWARE
Note: rear; turbo 82.76
AUTOPARTSOURCE CE471 CERAMIC PADS
Note: rear; oe ceramic; turbo 76.67
AUTOPARTSOURCE MF471 SEMI-METALLIC PADS
Note: rear; turbo 59.77
AMERICAN REMANUFACTURING INC. 63-D471 REAR PADS
Note: 4wd; rear 42.49
AMERICAN REMANUFACTURING INC. 66-D471 AXXIS DELUXE NAO PADS
Note: 4wd; rear 43.71
AMERICAN REMANUFACTURING INC. 62-D471 ROAD PROVEN INTEGRALLY MOLDED METALLIC (PMQ) PADS
Note: 4wd; rear 54.43
AMERICAN REMANUFACTURING INC. 65-D471 AXXIS METALMASTER PADS
Note: 4wd; rear 48.59
AMERICAN REMANUFACTURING INC. 68-D471 ROADPROVEN CERAMIC PADS
Note: 4wd; rear 74.90
AMERICAN REMANUFACTURING INC. 763-D471 DELTA ORGANIC (NAO) PADS
Note: 4wd; rear 32.25
AUTOSTAR PRIVATE LABELS 676B BONDED BRAKE SHOE
Note: rear 23.00
AUTOSTAR PRIVATE LABELS 676R RIVETED BRAKE SHOE
Note: rear *
AUTOSPECIALTY 15-471-12 REAR BRAKE PAD SET
Note: 4x4 68.18
AUTOSPECIALTY 25-471-01 BRAKE PAD REAR 52.80
AUTOSPECIALTY 23-471-01 HD PAD REAR 78.04
AUTOSPECIALTY 16-471-12 BRAKE PAD REAR 82.68
AUTOTEC1 AD471 BRAKE PADS
Note: rr.; plate #; fr. 3/92 *
AUTOTEC1 AMD471 BRAKE PADS
Note: rr.; plate #; semi-met.; bef. 3/92 *
AUTO EXTRA FRICTION AXMD471 PREMIUM METALLIC DISC BRAKE PADS
Note: rear; w/shims *
AUTO EXTRA FRICTION AXCD471 CERAMIC ENHANCED METALLIC DISC PADS
Note: rear *
AUTO EXTRA FRICTION AXOD471 ORGANIC DISC BRAKE PADS
Note: rear *
BECK/ARNLEY 082-1378 BRAKE PADS, PREMIUM ORGANIC 53.28
BECK/ARNLEY 086-1378C BRAKE PADS, CERAMIC 74.23
BECK/ARNLEY 087-1378 BRAKE PADS, SEMI-METALLIC
Note: oe pad material; replace oe semi-met w/semi-met only 53.91
BECK/ARNLEY 088-1378C BRAKE PADS, AXXIS CERAMIC 74.23
BECK/ARNLEY 088-1378D BRAKE PADS, AXXIS ORGANIC 64.71
BECK/ARNLEY 088-1378M BRAKE PADS, AXXIS SEMI-METALLIC
Note: oe pad material; replace oe semi-met w/semi-met only 59.88
BENDIX D471 CQ CERAMIC BRAKE PAD
Note: rear; oe ceramic *
BENDIX D471CT CT CERAMIC BRAKE PAD
Note: rear; oe ceramic 102.27
BENDIX MKD471 SEMI-METALLIC BRAKE PAD
Note: rear 93.76
BENDIX MKD471IQ IMPORT QUIET BRAKE PAD
Note: rear 93.76
BENDIX MRD471 GLOBAL SEMI-METALLIC BRAKE PAD
Note: rear *
BRAKE BEST MKD471 BRAKE PAD
Note: rear; semi-met *
BENDIX GLOBAL MRD471 SEMI-METALLIC BRAKE PAD
Note: rear *
CARQUEST BD471 BRAKE PAD
Note: rear; blue nao; organic premium pad; oe w/organic material; recommended replacement, 15" whls 65.16
CARQUEST GCD471 BRAKE PAD
Note: rear; gold non-ferrous ceramic; ceramic premium plus pad; oe w/organic material; 15" whls 114.30
CARQUEST RD471 BRAKE PAD
Note: rear; red nao; organic std pad; oe w/organic material; recommended replacement, 15" whls 29.72
CENTRIC PARTS 108.04710 AXXIS METAL MASTER BRAKE PADS
Note: rear; 4wd turbo *
CENTRIC PARTS 105.04710 POSI-QUIET CERAMIC BRAKE PADS W/SHIMS
Note: rear; recommended friction, sdn;, w/o abs *
Note: rear; recommended friction; wagon;, w/o abs *
Note: rear; recommended friction, sdn; 4wd *
Note: rear; recommended friction; wagon; 4wd *
CENTRIC PARTS 106.04710 POSI-QUIET EXTENDED WEAR PADS W/SHIMS
Note: rear, sdn; 4wd *
Note: rear, sdn;, w/o abs *
Note: rear; wagon;, w/o abs *
CENTRIC PARTS 107.04710 AXXIS DELUXE PLUS PADS
CENTRIC PARTS 109.04710 AXXIS ULT PADS
CENTRIC PARTS 100.04710 OEM FORMULA
CENTRIC PARTS 300.04710 CENTRIC PREMIUM BRAKE PADS
CENTRIC PARTS 102.04710 C-TEK STD METALLIC PADS
Note: rear; wagon; 4wd *
CONI-SEAL SCP471 CERAMIC BRAKE PAD
CONI-SEAL SMP471 PREMIUM METALLIC BRAKE PAD
Note: rear; turbo *
CARLSON QUALITY BRAKE PARTS D471 BRAKE PAD
Note: rear; legacy listing *
DURA INTERNATIONAL D471 BRAKE PAD
Note: rear; disc *
DURA INTERNATIONAL 676 BRAKE SHOE
Note: rear; drum *
FEDERATED BRAKES D471 ORGANIC PREMIUM BRAKE PAD
Note: rear; 15" whls; oe organic; recommended replacement *
FEDERATED BRAKES D471C CERAMIC PREMIUM BRAKE PAD
Note: rear; 15" whls; oe organic *
FEDERATED BRAKES MD471 SEMI METALLIC PREMIUM BRAKE PAD
FRICTION MASTER MKD471 SEMI-METALLIC BRAKE PAD
Note: rear *
FRICTION MASTER MX471 PREMIUM SEMI-METALLIC BRAKE PAD
Note: rear; oe recommended material *
FRICTION MASTER CMX471 CERAMIC BRAKE PAD
Note: rear *
GUARDIAN BRAKE PRODUCTS 61-471 BRAKE PADS
Note: rear; fr 3/92 *
GUARDIAN BRAKE PRODUCTS 65-471 BRAKE PADS
Note: rear; to 3/92 *
GUARDIAN RETAIL 65-7351 REAR SEMI-METALLIC PAD
Note: 4x4; recommended oem rpl; before 3/92 *
HAMPDEN AUTOMOTIVE MD-471 BRAKE PADS
Note: w/15" wheels; rear set 64.00
Note: w/14" wheels; rear set 64.00
HAMPDEN AUTOMOTIVE HDD-471 BRAKE PADS
Note: w/optional rear heavy duty; rear set 73.90
INWOOD DMX471 DISC BRAKE PAD
Note: rear; intimidator *
INWOOD PDMX471 DISC BRAKE PAD
Note: rear; intimidator plus professional grade *
INWOOD M471 DISC BRAKE PAD
Note: rear; prem semi met pads {superceded by dmx471} *
INWOOD S471 DISC BRAKE PAD
Note: rear; superiorone plus *
INWOOD SP471 DISC BRAKE PAD
Note: rear; spectraone plus *
INWOOD SPQ471 DISC BRAKE PAD
Note: rear; ultraquiet *
KEMPARTS CMD471 FRICTION PRO CERAMIC PADS
Note: rear 94.11
KEMPARTS MXD471 FRICTION PRO CARBON METALLIC PADS
Note: rear 85.71
KEMPARTS XD471 FRICTION PRO NAO/LOW-MET PADS
Note: rear; oe recommended 59.19
KEMPARTS D471 PERFECT VALUE NAO PADS
Note: rear 41.21
KEMPARTS MD471 PERFECT VALUE SEMI-MET PADS
Note: rear 45.45
MINTEX MDB1497 BRAKE PAD
Note: rear; disc *
Note: rear; sumitomo *
MEVOTECH INC. 7351 REAR BRAKE PAD SET
Note: 4x4 *
MEVOTECH INC. MM7351 REAR SEMI-METALLIC PAD
MEVOTECH INC. MT7351 REAR SEMI-MET PAD-PREMIUM
MEVOTECH INC. XP7351 REAR ASBESTOS-FREE PAD
MIGHTY MD471 PAD/SHOE - OE REPLACEMENT
Note: rear *
MIGHTY MD471K PAD/SHOE - OPTIONAL UPGRADE
Note: rear *
NEW JERSEY AMERICAN SSD471 REAR SEVERE DUTY PADS
NEW JERSEY AMERICAN MD471 REAR PREMIUM SEMI-METALLIC PADS *
NU-GEON 45-04710M AXXIS XBG SEMI-METALLIC
Note: rear 63.90
NU-GEON 45-04710D AXXIS DELUXE
Note: rear; recommended oe replacement 51.21
NEWTEK AUTOMOTIVE CRD471-7351 ADVANCED CERAMIC DISC PADS-POSITIVE MOLDED
Note: rear *
NEWTEK AUTOMOTIVE IMD471-7351 PREMIUM METALLIC DISC BRAKE PADS
Note: rear *
NEWTEK AUTOMOTIVE SMXD471-7351 CERAMIC ENHANCED METALLIC DISC PADS
Note: rear *
ONESOURCE FRICTION D471 ORGANIC BRAKE PADS
Note: rear; from 3/92 *
PARTS DEPOT PREFERRED MKD471 SEMI-METALLIC BRAKE PAD
Note: rear *
PARTS DEPOT PREFERRED MX471 PREMIUM SEMI-METALLIC BRAKE PAD
PARTS DEPOT PREFERRED CMX471 CERAMIC BRAKE PAD
Note: rear *
PARTS MASTER/MORSE MD471 BRAKE PAD
Note: rear; md *
PARTS MASTER/MORSE MKD471S BRAKE PAD
Note: rear; mkd; oe recommended material *
PARTS MASTER/MORSE CMX471 BRAKE PAD
Note: rear; cmx *
PARTS MASTER D7351 REAR BRAKE PAD-ORGANIC
Note: 4x4; recommended oem rpl; from 3/92 *
PARTS MASTER MKD471 DISC PAD
Note: rr.; pr. *
PARTS MASTER MD471 REAR SEMI-METALLIC PAD
PARTS MASTER MD7351 REAR SEMI-METALLIC PAD
PRONTO SCP471 CERAMIC BRAKE PAD
PRONTO SMP471 PREMIUM METALLIC BRAKE PAD
Note: rear; turbo *
PRONTO PAD471 BRAKE PADS
Note: rr.; lining #; fr. 3/92 *
PRONTO PS471 BRAKE PADS
PARTS PLUS BLUE FRICTION PPB471 ORGANIC BRAKE PAD
Note: rear; 15" whls, oe organic *
PARTS PLUS BLUE FRICTION PPB471M SEMI-METALLIC BRAKE PAD
PARTS PLUS GOLD DISC PADS PPD471 ORGANIC BRAKE PAD
POWER STOP 16-471 Z16 CLEAN RIDE CERAMIC BRAKE PADS
Note: rear; oe ceramic; rear disc *
CARQUEST/RAYBESTOS BCD471 CERAMIC PREMIUM BRAKE PAD
Note: rear; 15" whls; oe organic 97.16
CARQUEST/RAYBESTOS BD471 ORGANIC PREMIUM BRAKE PAD
Note: rear; 15" whls; oe organic; recommended replacement 65.16
CARQUEST/RAYBESTOS GCD471 CERAMIC PREMIUMPLUS BRAKE PAD
Note: rear; 15" whls; oe organic 114.30
CARQUEST/RAYBESTOS GSD471 SEMI METALLIC PREMIUMPLUS BRAKE PAD
Note: rear; 15" whls; oe organic 91.34
CARQUEST/RAYBESTOS RD471 ORGANIC STANDARD BRAKE PAD
Note: rear; 15" whls; oe organic; recommended replacement 29.72
CARQUEST/RAYBESTOS RMD471 SEMI METALLIC STANDARD BRAKE PAD
Note: rear; 15" whls; oe organic 37.67
QUALITEE INTERNATIONAL CE471 REAR PADS VGX CERAMIC
Note: 4wd, sdn 76.67
Note: sdn, exc 4wd; wagon; w/14" whls 76.67
Note: sdn, exc 4wd; wagon; w/15" whls 76.67
QUALITEE INTERNATIONAL MF471 REAR PADS VGX STEALTH
Note: 4wd, sdn 59.77
Note: sdn, exc 4wd; wagon; w/14" whls 59.77
Note: sdn, exc 4wd; wagon; w/15" whls 59.77
QUALITEE INTERNATIONAL MF471K REAR PADS VGX CLAMSHELL
Note: 4wd, sdn 82.76
Note: sdn, exc 4wd; wagon; w/14" whls 82.76
Note: sdn, exc 4wd; wagon; w/15" whls 82.76
QUALITEE INTERNATIONAL PF471 REAR PADS PERFORMANCE PLUS ORGANIC
Note: 4wd, sdn 39.49
Note: sdn, exc 4wd; wagon; w/14" whls 39.49
Note: sdn, exc 4wd; wagon; w/15" whls 39.49
RAYBESTOS ADVANCED TECHNOLOGY ATD471C SUPER PREMIUM CERAMIC BRAKE PAD
Note: rear; oe organic; 15" whls *
RAYBESTOS ATD471C ADVANCED TECHNOLOGY CERAMIC BRAKE PAD
Note: rear; 15" whls; oe organic 107.91
RAYBESTOS PGD471 PROFESSIONAL GRADE ORGANIC BRAKE PAD
Note: rear; 15" whls; oe organic; recommended replacement 64.67
RAYBESTOS PGD471C PROFESSIONAL GRADE CERAMIC BRAKE PAD
Note: rear; 15" whls; oe organic 89.43
RAYBESTOS PGD471M PROFESSIONAL GRADE SEMI METALLIC BRAKE PAD
Note: rear; 15" whls; oe organic 97.05
RAYBESTOS PGD471QS QUIET STOP CERAMIC BRAKE PAD
RAYBESTOS RPD471M RAYMOLD SEMI METALLIC BRAKE PAD
Note: rear; 15" whls; oe organic 44.28
RAYBESTOS SGD471M SERVICE GRADE SEMI METALLIC BRAKE PAD
REMSA OF AMERICA GMKD471 GOLD PREMIUM SEMI MET PADS W/SHIMS
Note: rear; w/15" whls *
Note: rear; w/14" whls *
REMSA OF AMERICA ICD471 GOLD PREMIUM CERAMIC PADS W/SHIMS
REMSA OF AMERICA MKD471 SILVER SEMI METALLIC PADS W/O SHIMS
REPLEX AUTOMOTIVE D471 DISC BRAKE PAD
Note: rear; w/14" wheel solid rear disc; fmsi: 7351 *
Note: rear; w/15" wheel vented rear disc; fmsi: 7351 *
AUTOSTAR PREMIUM DISC PADS D471 PREMIUM ORGANIC BRAKE PAD
AUTOSTAR PLATINUM DISC PADS DS471 PLATINUM ORGANIC BRAKE PAD
AUTOSTAR PLATINUM DISC PADS MDS471 PLATINUM SEMI-METALLIC BRAKE PAD
SACHS MFR372D BRAKE SHOES
Note: rear; optional; sport, vin 6 listing. *
SATISFIED BRAKE PRODUCTS PR471 PRO SERIES PERFORMANCE BRAKE PAD
Note: rear; recommended replacement part# for this application *
SATISFIED BRAKE PRODUCTS PR471-C PRO SERIES CERAMIC BRAKE PAD
Note: rear *
SATISFIED BRAKE PRODUCTS CL471 PRO SERIES CLASSIC BRAKE PAD
Note: rear *
SATISFIED BRAKE PRODUCTS CL471-Q PRO SERIES CLASSIC PLUS BRAKE PAD
Note: rear *
SATISFIED BRAKE PRODUCTS MPD471 ULTRA SERIES BRAKE PAD
Note: rear *
SATISFIED BRAKE PRODUCTS PD471 NON-ASBESTOS ORGANIC BRAKE PAD
Note: rear *
USI/AUTO EXTRA AD-471 PG PLUS PREMIUM ORGANIC BRAKE PAD
Note: rear; 15" whls; oe organic, recommended replacement *
USI/AUTO EXTRA AD471 PG PLUS PREMIUM ORGANIC BRAKE PAD
USI/AUTO EXTRA AXOD471 PG PLUS PREMIUM ORGANIC BRAKE PAD
USI/AUTO EXTRA AXMD471 PG PLUS PREMIUM SEMI-METALLIC BRAKE PAD
USI/AUTO EXTRA SMD-471 PG PLUS PREMIUM SEMI-METALLIC BRAKE PAD
USI/AUTO EXTRA SMD471 PG PLUS PREMIUM SEMI-METALLIC BRAKE PAD
STEWART RIDDLE CRD471 VORTEX CERAMIC OE REPLACEMENTOE REPLACEMENT BRAKE PAD
Note: rear; disc *
STEWART RIDDLE VSD471 VORTEX SUPER PREMIUM POSITIVE MOLDED BRAKE PAD
Note: rear; disc *
STEWART RIDDLE XXD471 ECONOMY NON-ASBESTOS ORGANIC BRAKE PAD
Note: rear; disc *
STEWART RIDDLE D471 BASE NUMBER BRAKE PAD
Note: rear; disc *
STEWART RIDDLE SPD471 APPLICATION SPECIFIC WITHOUT SHIMS BRAKE PAD
Note: rear; disc *
STEWART RIDDLE SQD471 APPLICATION SPECIFIC WITH SHIMS BRAKE PAD
Note: rear; disc *
STEWART RIDDLE XMD471 ECONOMY SEMI-METALLIC BRAKE PAD
Note: rear; disc *
TRUST DISC PADS D471 ORGANIC BRAKE PAD
MINTEX BRAKES-TMD FRICTION MDB1497 BRAKE PAD
Note: rear; wagon; w/rear disc brakes *
MINTEX BRAKES-TMD FRICTION MDB1497X MINTEX PADS XTREME
Note: rear; sdn *
Note: rear; sdn *
TRUST MD471 REAR SEMI-METALLIC PAD
Note: 4x4; metalazer; recommended oem rpl; to 2/92 *
TRUSTAR CBP471 CERAMIC BRAKE PAD
Note: rear; oe ceramic; turbo 64.02
TRUSTAR PPM471 PREMIUM METALLIC BRAKE PAD
Note: rear; turbo 48.45
UNIVERSAL BRAKE PARTS 676B BONDED BRAKE SHOE
Note: rear 29.50
UNIVERSAL BRAKE PARTS 676R RIVETED BRAKE SHOE
Note: rear *
WAGNER ZX471 QUICKSTOP BRAKE PADS
Note: rear; to 3/92 67.52
WAGNER ZD471 QUICKSTOP BRAKE PADS
Note: rear; from 3/92 52.66
WAGNER MX471 THERMOQUIET BRAKE PADS
Note: rear; to 3/92 104.22
WAGNER PD471 THERMOQUIET BRAKE PADS
Note: rear; from 3/92 72.70
WORLD BRAKE CMX471 PREMIUM CERAMIC BRAKE PAD
Note: rear *
WORLD BRAKE MD471 SEMI-METALLIC BRAKE PAD
Note: rear *
WORLD BRAKE SMX471 CERAMIC ENHANCED SEMI-METALLIC BRAKE PAD
Note: rear *
WORLD BRAKE SP471 POSITIVE MOLD PREMIUM SEMI-METALLIC BRAKE PAD
Note: rear *
WORLD BRAKE VD471 POSITIVE MOLD HIGH PERF SEMI-METALLIC BRAKE PAD
Note: rear *
WAGNER CATEGORICAL NUMBERS ZX471 QUICKSTOP BRAKE PADS
WAGNER CATEGORICAL NUMBERS ZD471 QUICKSTOP BRAKE PADS
WAGNER CATEGORICAL NUMBERS MX471 THERMOQUIET BRAKE PADS
WAGNER CATEGORICAL NUMBERS PD471 THERMOQUIET BRAKE PADS
EUROROTOR ID471 F1 ICE BRAKE PADS
Note: rear *
EUROROTOR LD471 F1 LIGHT BRAKE PADS
Note: rear *
AUTOZONE/DURALAST MKD471 BRAKE PAD
Note: rear semi-met; consistent & effective braking; w/shims incld where applicable *
AUTOZONE/MIDAS BP1491C Z-MIDAS BRAKE PAD/SHOE - REAR
Note: ceramic pad *
AUTOZONE/MIDAS BP1491M Z-MIDAS BRAKE PAD/SHOE - REAR
Note: metallic pad *
AUTOZONE/VALUECRAFT MKD471V BRAKE PADS
Note: rear semi-met; smooth, quiet stopping *
REAR BRAKE PAD SHIMS
AIMCO BQ110 PAD SILENCER SHIMS
Note: brake quiet kit; rr.; oe supplied w/shims;use w/{spm471} 16.60
AUTOSPECIALTY SH-1328 PAD SHIM KIT REAR 11.56
BETTER BRAKE PARTS 8796 DISC PAD SHIM KIT
Note: rear *
CARLSON QUALITY BRAKE PARTS 18048 DISC BRAKE PAD SHIM KIT
Note: rear; fmsi pad/shoe ref# d471 9.24
Note: rear; w/4dr; fmsi pad/shoe ref# d471 9.24
Note: rear; w/station wag; fmsi pad/shoe ref# d471 9.24
FEDERATED BRAKES DS8048 BRAKE PAD SHIMS
Note: 15" or 14" whl.; rr. *
MIGHTY 18048 REAR SHIMS SELF ADJ. KIT
Note: exc. 4x4 turbo; *
PARTS PLUS BRAKE HARDWARE P8796 DISC PAD SHIM KIT
Note: rear *
RAYBESTOS DS8048 PG PLUS BRAKE PAD SHIM
Note: rear; 15" whls 12.85
SATISFIED BRAKE PRODUCTS STM197K SHIM
Note: rr.; legacy awd turbo fr. 2/92 12.11
WAGNER SH305-5 SHIM
Note: rr. 12.10
WAGNER PQ300122 REAR PAD SHIM KIT
Note: 4x4 5.90
WAGNER CATEGORICAL NUMBERS SH305-5 SHIM
Note: rr. 12.10
BRAKE LINING/FRICTION, PARKING BRAKE SHO
CENTRIC PARTS 110.07940 PREMIUM PARKING BRAKE SHOES
Note: rear; sdn, 4wd; parking brake shoe *
Note: rear; wagon, 4wd; parking brake shoe *
EUROROTOR ES794 BONDED BRAKE SHOES
Note: rear *
