How about a variable intermittent wiper? The fixed intermittent wiper was always a pet-peeve of mine.
Saw these at the local Pick-N-Pull, figured what the hell....
How freakin' true!!!PhyrraM wrote:They say it's the small things that matter most, right?
Thanks!fatgc8 wrote:very nice and detailed writeup man keep up the good work.. i guess its very rare people are building these like you are anymore with informative pictures.. i really like your setup...
For the final turbo, I have a 90 degree inlet TD05 from a ~'95 WRX. The smaller turbos were mainly for testing so I wouldn't have to change the tune.BC5RA wrote:Not sure what you're going to do ultimatly, But neither of those turbos will flow 300hp if you had to pick one then pick the TD04 mainly because its newer tech will spool a bit quicker then the VF10.
I do have the intercooler, but have not sourced a pump or heat exchanger yet. The proper JDM parts are hard to come by and it seems the OEM Subaru pump has occasional bearing problems. If I do a water-to-air intercooler I'll most likely follow Josh's lead.BC5RA wrote:Also can you get a hold of a WAIC?
Coming from a RS/RA owner I'll take that as a complement.BC5RA wrote:Nice work
The best pump gas here (without spending 3x the price) is 91 octane, close to 95.5 using the more common RON rating used in the rest of the world. I currently only have a black series 2 exchanger and the twin pipes mounted on the intake manifold. Anything mounted on the chassis itself I do not have yet.BC5RA wrote:Oh a TD05 will flow plenty, What parts do you require? what sort of gas can you guys get a hold of?
Here is Josh's latest intercooler thread. http://bbs.legacycentral.org/viewtopic.php?t=35394BC5RA wrote:Could you give me a link to Josh's setup?, the pumps do fail but not that often, MRT in Australia used to a larger heat exchanger and highflow pump (the heatexchanger was basically two welded together.
Basically a closed deck EJ22. Same crank and rods as EJ20G RS/WRX with a cast piston @~8.0:1 compression. Very small turbo, non-intercooled. SOHC heads, most likely very similier to your EJ18 SOHC heads. Wasted spark coilpack instead of your coil-on-plug setup. Built for low end torque that us Americans supposedly love. The good news is that our harness and ECU pinouts are 98% compatable with EJ20Gs. Only a few pins to swap, so the PFC conversion was very easy.BC5RA wrote:I'm pretty out of touch with the setup of USDM legacys.
Yeah, self done road tunes for now. I tend to prefer good condition used parts. These cars ARE 15 years old now, right? As soon as I get my EJ22 hybrid (EJ22 or EJ25 block w/ EJ20G heads) installed I plan to get a proper dyno tune. It's a shame that dyno time is so expensive, I really would have liked to add real numbers at every stage of the build so far.BC5RA wrote: I take it you'll collect all these parts and then tune it with aforementioned Power FC.
I will. Thanks.BC5RA wrote: Let me know I'd be happy to help, we've still got loads of parts over here easy to take for granted.
Ditto.BC5RA wrote:I always appreciate anybody who learns and works on there own cars, and i like white legacys
