Does anyone know any history on this 1990 legacy ss, seattle
apparently it was purchased in Washington state, and driven to NY where I have bought it for $1200.
it seems to have had multiple front collisions and a stupid white-face gauge kit, the panels are three different colors, sprayed over red. 127k~ on the OD, AWD engine doesn't seem original, Sti rims.
If anyone has any history on this car it would be incredible.
-thanks
Aaron.
Re: Does anyone know any history on this 1990 legacy ss, sea
I just saw it on.craigslist for years. It's not an SS, but a swapped 90. That's all I got.
I was about to say that's a build car cause from what I have read SS started in 1991 so it was probably similar to my car i.e. 1990 legacy L fwd I don't know if its an auto if so then yeah like mine then they did what I want to do. More then likely a stock turbo for a SS turbo ecu and pulled an awd setup either by part or from donor car with matching tran. and tada you have yourself "SS"
91 Legacy L (AT, FWD)-crashed 2/3/14
95 Legacy L (AT)
05 Outback XT (AT)
92 Legacy L (MT,AWD)
95 Legacy L (AT)
05 Outback XT (AT)
the car is AWD/RWD original, the motor may be newer than the car (maybe replaced after collisions) but it has a sport sedan decal in the front left, 1990 on the title, VIN says 1990. oil cap says 1990, could it Just be like a 91 model year stamped as 90? the badges on the trunk lid are legacy turbo, awd abs etc. it's boggling my mind to think it could all be swapped, someone would have to be more then dedicated.Nohbdy wrote:I was about to say that's a build car cause from what I have read SS started in 1991 so it was probably similar to my car i.e. 1990 legacy L fwd I don't know if its an auto if so then yeah like mine then they did what I want to do. More then likely a stock turbo for a SS turbo ecu and pulled an awd setup either by part or from donor car with matching tran. and tada you have yourself "SS"
could it be like a 1990 Subaru legacy rs? I really cant believe this car would have that much work done to it, it's stock otherwise, is there any way I can definitively tell other than "there's no such thing as a 1990 Subaru legacy ss"
you guys must be right it doesn't add up at all.
two words: no sunroof.
Someone swapped.
Someone swapped.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Just did the autocheck. reported miles were 274k in 2003, one collision in 2003. nothing is original.dscoobydoo wrote:two words: no sunroof.
Someone swapped.
mike-tracy wrote:I just saw it on.craigslist for years. It's not an SS, but a swapped 90. That's all I got.
so for $1200 was it a decent deal do you think?
what was it for sale for on Seattle CL however long ago if you can remember.
It was very over priced IMO on craigslist. $4500 or so? Someone on here checked it out and noted the salvage title. For a running and driving turbo car, I think $1200 is a great deal.
I would have to agree I want an ss but all the ones i find are far away or more money then I have and as a note about the back that says turbo if I looked at it right that whole back plastic panel is held on by screws so wouldn't be too hard if you're already swapping parts to swap that too. But sadly we will never truly know what happened to get you that car or where it has been all we can tell is you own it and at a hell of a price.
95 Legacy L (AT)
05 Outback XT (AT)
95 Legacy L (AT)
05 Outback XT (AT)
One way to check if its swapped or not is the engine code on the vin plate on the drivers strut tower. If it says ej22e, its swapped for sure.
Danny
yep, ej22e on the vin plate
Re: 1990 legacy ls legacy ss "clone" turbo, Greene, New York
can you inbox me some pix of the hood scoop from under the hood?
turbo970 wrote:can you inbox me some pix of the hood scoop from under the hood?
if you want? it's just a normal hood with a cheap ebay scoop riveted on
is the scoop functional ?
yes although there's no intercoolerturbo970 wrote:is the scoop functional ?
i wanna add a scoop like that to my tw
Was this car from the Northwest? And does it have a white gauge cluster?
it did have a white gauge cluster, but it was faulty and now has working cluster from a 94 hadn't left Seattle until last year I bought it from the owner here in NY.robertpaige wrote:Was this car from the Northwest? And does it have a white gauge cluster?
Yes it is the red one that showed up on Seattle CL for like... years...
Crazy. Saw that car on CL for a long long time.
Wish I knew what the person was selling it for then, some members said it was unreasonably high and no-one ever bought it.robertpaige wrote:Crazy. Saw that car on CL for a long long time.
I had been trying to track down information on it for well... Forever.
things like this:
http://honda-tech.com/showthread.php?t=298732
Just makes me wonder.
