440CC twin turbo injectors are EXACTLY the same as some 270c
douglas vincent
Post by douglas vincent »
270 cc on the left, 440 cc on the right.
Until I swap the twin cam heads over, I am just swapping the injectors over. So I popped them out, grabbed some fuel rails and got lucky with the right year and simply swapped them out. the fuel rails from the twin turbo DO NOT swap over.
And no, I do not know what year the 270 cc injectors are from.
I believe those 270cc/min injectors are from a pre-facelift non-turbo automatic.
vrg3 wrote:I believe those 270cc/min injectors are from a pre-facelift non-turbo automatic.
You are correct.
douglas vincent
then those would be 1991 Auto wagon....
