Up and down boost under same throttle accel.
Radial GT1
Car. 93 4eat
Under normal driving acceleration I can actually watch the boost go up and down from 4 psi to 6 psi and after about 20 seconds of that it will jump up to full boost and back down again. It is kinda bothersome. If i really hop on it to the point the power light turns on the boost seems to hold steady and 8-9 psi. But I don't like to do that all the time for obvious reasons.
Could it be the silonoid giving me problems? I have no CEL's. I have searched for this and haven't found anyone with the same problems. Thanks for reading.
check the connections of the boost gauge, sounds like you are leaking somewhere, probably have old loose hoses in there somewhere under the hood, most likely at a "T" connector, and they need to be nice and tight all over to read boost correctly.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Radial GT1
True but the power goes up and down even if the turbo is showing constant pressure. It is not the boost going up and down that concerns me, it is the lack of power.
Boost will be steady and it will feel like I am driving with no boost at all. And than all of a sudden it (ECU) will change something and bam it has power, all with the nearly same boost reading. I can hear the turbo all spooled up and working. Somethin' is screwy.
00 Camry; No wrenchin', just drive. Thank you Japan!
93 Legacy SS 4Eat 96K; All the wrenching I could ask for.
[quote="un-named"]What a man & a woman, and another man with a sheep & a midget want to do is their own business...[/quote]
92ss satinsvoice
sounds like your cars running rich. or really lean.
is your maf senser workin properly?
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
94 L n/a 5spd, Rip
Radial GT1
I don't know. How would I check? It gets 18 er so MPG in town which sounds about normal.
The boost problem seems to have gotten worse with this cold weather. On a long up hill pull to boost varies from 4psi to 11 psi without my foot moving the throttle, and it does that up and down boost the whole time. It is not just my gauge giving the wrong information, I can hear the turbo changing speed, and the power jumps up and down too. What do you think?
bmxkelowna
Radial GT1
Still stock. Wouldn't those parts throw a check engine light??
edit: The car has 92K on it
TPS
Mine used to fuck with me like that on my first turbo legacy.
I had no boost gage, but the car surged all over like that.
I changed out the whole throttle body on mine which seemed much easier than installing and calibrating a new TPS.
....worked for me.
....worked for me.
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
Radial GT1
That sounds like my problem. Yesterday I was looking at houses for about 2 hours. Driving through city streets at low speeds. And when I would push on the gas lightly to go slow, it would stall a little bit, a couple times it actually died. This is an auto here it should not be dieing. The check engine light also came on for like a minute and then turned off. TPS, I'm going to subaru monday to get one. I'll give it a shot.
Radial GT1
Radial GT1
Ok,
Update here.
I picked up a known good used TPS, and installed it yesterday. It from what I can tell did nothing. I checked voltage from pins 1 and 3 and it is a bit better than the old one was as far as being close to the numbers it should be. The swap did fix the initial stumble the engine had when getting on and off the gas at slow speeds. It did also fix the idle a little bit, but it is also rainy so it could just be the change of weather that is making it run a little different.
Same problems though. Low power in the boost unless I can over half throttle and giving it hell. Boost going from 5-8 psi on its own with my foot at the same position on the throttle. What other sensors will cause this kind of funk-ness?
Update here.
Knock sensor. Have you updated to the revised knock sensor, old one would get cracks in it. The ECU might be logging a lot of knock counts and holding back the boost because of it, there is a span where the knock count can be high enough to pull boost but not high enough to trigger the CEL. (I have seen this many times on my car)
Did you ever read that stored code the car threw? If knock sensor is any of them, then you need to get the updated one.
Radial GT1
I had a CEL for the knock sensor when I bought the car a year ago, and replaced it with a new one from subaru. I just cleared the codes just in case it would do anything. Nope, same deal. Although I did have a TPS and a idle position code that was fixxed by changing out the TB. Codes are all gone now, all clear.
Boost still goes up and down, and boosting at 1/4 throttle is worthless, I think it gets slower in boost if I am not driving it hard.
Arctic Assassian
Radial GT1
It is stock, Do they have a tendency to fail? I will pull it off and check, that is something I didn't think to check.
