PS: It's going to be a slow start for a few days untill my BOV get's here.
PPS: I hearby take no blame in any errors I may have made result in damage of your own personal vehicle.
Step One: Buy WRX Intercooler. I'm still debating if a silicone Samco hose or something would make a better Y-Pipe. For now I'll be using the stock one. Notice in the pic that there is no BOV. Now from what I have read we cannot use the stock BOV on the stock IC. I suggest you pick up a different one of some sort. My choice has been a Forge. I'll get pics with the BOV and IC when I get it in.
Step Two: Replace the stock Y-Pipe for ease of fit. The stock Y-Pipe on the WRX is very small and very brittle. It will not provide the flex needed to make the installation easy. I picked up a Samco Y-Pipe used for 40 bucks. The process to remove the old Y-Pipe is to just get a flathead screwdriver and undo the two clams holding it onto the intercooler. Installation for the new Samco Y-Pipe went in the opposite order. Sorry for being so slow on getting these things, done. I'm trying to get the info and pics up as fast as I can given the period that I have to work on the car. *Note* - You can use the stock Y-Pipe but since I am not going to use it, I suggest going this route.
Step Three: Moving the coolant tank. Sorry, about the shitty picture, but your going to need to move your coolant tank from it's current location in order for the WRX IC to fit. You may do this however you want, but I'm going to decribe my method. What I did is buy a WRX Coolant tank. Since my AC is removed I had some extra space there and decided to make it fit. I took off the stock tank and waited for the coolant to drain out. There are *I think* four lines going to the tank. The smallest one going to the overflow tank, the next largest one going to the hard coolent line connecting to the radiator and, finally the last two are the same size. One goes to the turbo for coolant flow and the other one to the coolant line that I think comes from the water pump. All of these lines correspond with the size fitting off the WRX coolant tank. I bought 10 feet of the bigger hose, and 2 feet of the next to smallest hose(not sure on size). Next, I mounted the tank. This consisted of using the connector that hung down and was a half circle. I just found a bolt that I could screw into the stock AC mount, then placed the tank on the screw and tightened. This isn't the best discription of the whole process, but if there are any questions I can take pics upon request. A final note is that some of the lines were a tight fit. It is up to you to make them work and find your own place to route them. As a tip, I'd suggest sending some of them under the intake manifold.
Step Four:Making it fit. I'm guna go in steps here. It's not finished so I'll get that done later.
1) Take off the TB to Turbo tube. There are two clamps that need to be loosened with a flat head screw driver. Undo those, find all the little hoses going to it and disconnect those. I think that there are 2 hoses going to that tube. One is off the intake and is the bigger one and one is a small vaccuum line that is on the right side connected to the diverter valve.
Set this aside for now.
2) Move the ignitor. It has two 10mm bolts. One under the main harness and one that you can see. Undo those and take it off after disconnecting it from the plug. You can see where it was once mounted.
3) Test fit. Just put it up there and take a look at what needs to be moved and hammered in to make it fit.
5) Hammer time. Your guna smash the shit out of your fire wall where it needs to be hammered and the little thing where the ignitor sat on. Have fun. I may have went a little far...
6) Test fit it again. After the pounding is done the IC should slide in a little ways then get hung up on the throttle body. Your going to have to shave some metal off your TB or IC. Your call on the place and how much.
Step 5:Hookin it up. I really don't want to show any pics of what my setup looks like, because it looks like arse. I had to hack my Samco up, find some 2in exhaust pipe, hack that up, buy some radiator hose, hack that up, then hack my stock TB tube up. All I have to say it OYE! Never ever do this ever. You guys can be the ones who makes this baby work. I've never been so frustrated by this damn car ever. The WRX IC is so not ment to fit in our cars. For sake of everything, please go by a SAAB 900 IC or do something besides this thing. The car pulls like a bat outa hell though. I do enjoy that and the BOV now. Other then this. I hate the setup. I'm going down to a local speed shop this week to have a custom hard pipe made. Perhaps then it will look and run a little better.
NOTES: Your going to have to shave the IC or TB a lot to get it to fit. There are 3 hoses that are attached to the IC. One is from the valve cover on the drivers side. Hook that up to the pipe on the IC. The other one is off of the other valve cover. Hook that up. The last one come off the compressor inlet and goes on the IC pipe also. The big line for the DV in the back needs to be plugged. I think it's a 1in OD hole and a 3/4 ID. Find something to plug that with. Other then that the car runs pretty good.
