help choosing head
help choosing head
wich head should i get for my ej22t? i want to make serious power over 300 whp, running fmic, revtronix tunable chip(comming soon) and water meth injection ... so my ej22t head wont do... want to do the dohc conversion but dont know what to choose..
2.5 rs head... but dont think they are made for boost?
old sti head?? i dont want to do any wiring and want to keep my ecu...
and i'll need an other manifold or can keep the ej22t manifold??
thanks!!
thanks!!
impreza 95, ej22t engine swap!
Intake manifold:
If your going to eliminate or do custom PCV, go for the USDM EJ25D. It will work with the factory coil, IAC, and throttlebody.
If you want the ultimate in OEM, drop in look go with an EJ20G intake manifold. But get it COMPLETE. PCV, fuel, etc...
Heads:
Best power, EJ20K. Best availability: EJ25D, but need work to get the oil and coolant lines. Best comprimise for the price: WRX EJ20G
Heads:
- quasi-mod-o
SOHC Ej251 heads aren't an option for you with that ECU. Ej20G, EJ20k and Ej25d are your choices. Oh, and Ej20R and Ej20H TT heads. Read the unspoken details thread. You'll learn a lot.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
You can make 300whp on 22T heads and reground cams. It just depends on whether or not you are going to pony up for the supporting mods. There is no free lunch in the Subaru world.
You have a ton of other things to worry about when making that kind of power on a first gen Legacy. Clutch & driveline, fuel system, and ton of other things. Even the wasted spark ignition system struggles at that power level.
my setup is corectly built! just neeed other head! and yea coilpack i've to admit i've problem with this even at low boost... i need to upgrade this too but dont really know what it need, i've seen neon coil pack i think??
for fuel i've walbro 255, 550cc injector(will get 800cc or more soon) 3 inch turbo back, will have soon: water meth injection,fmic,external wastegate
thats why i think head upgrade is now needed! ahah
