Tearing things down.. I might go a different direction so these heads can go.
Rebuilt EJ22T heads, all seals replaced with OEM, surface decked and a handful of new valves, valve job done, Delta 220 grind cams. The bulk of the reassembly (valves etc), was done elsewhere.
Driven <10miles
$350ish, local please.
Rebuilt heads for sale w Delta cams
Subaru-less
Re: Rebuilt heads for sale w Delta cams
Location? Any tardes? Do you need a tune with these because of the cams?
Auburn, Washington. Don't really need any trades and really not looking to ship these.
These don't require a different tune and there are many others with the same cams on the bbs-- can search for a little bit more information if interested.
Subaru-less
hmm, bump.
maybe trades could be interesting too.
Subaru-less
+1 for running these without a tune works perfect and the lumpy idle is fun
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
