Portland, OR - ISO DOHC SWAP
YetiSmasher
Post by YetiSmasher »
Looking to swap my ej22t to DOHC. Does anybody have the item's necessary for the swap?
I'm also looking to upgrade my 440 robtune to the 550. With that being said, does anybody also have ej25d rails and 550 yellow injectors?
Thanks, Ben
Imprezafan93
Re: ISO DOHC SWAP
Post by Imprezafan93 »
I have ej25d rails, and if you want to go wrx heads which i think is the best i have a set of wrx heads.
Rails-55 shipped
Wrx heads-400 shipped
robertpaige
ISO DOHC SWAP
Post by robertpaige »
I've got EJ20G HLA heads. Complete with cams and all that jazz. I'm local too. PM me. I'd take $250 for em
WRX heads would be cool but you'd have to do a lot of wiring. 20G heads are plug and play with a robtune or something else.
RoughDiamond
Re: ISO DOHC SWAP
Post by RoughDiamond »
Have a set of 20G (Legacy heads, HLA style) and a RA 5th injector manifold, if interested.
1991 Legacy SS (BC) EJ22T // 4EAT // Pewter Metallic (Sold)
1991 Legacy SS (BC) EJ22T // 5MT // Rio Red (Sold)
1991 Legacy SSRS (BC) EJ20G (Full COP and AWIC Swap) // 5MT // White Pearl Tri-Coat Africa Rally replica in progress.
chanley2010
Re: ISO DOHC SWAP
Post by chanley2010 »
Im running the ej25d heads on my 22 block and they have worked great! Just make sure you use a dremel or something to modify the head gaskets and definitely look into running cometic thatare .015 thinner then stock! Cheers
dscoobydoo
Re: ISO DOHC SWAP
Post by dscoobydoo »
Should have come here first. I have the heads and intake. Rob also has a spare ecu of mine
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
YetiSmasher
Re: ISO DOHC SWAP
Ill hit you up in a little bit drew
ur_a_bus
Re: ISO DOHC SWAP
Post by ur_a_bus »
Bump, i have a set of EJ20G heads PM for info
