Stuffing the EJ22T from my '92, into a '91 LSi Wagon.
TheSubaruJunkie
Post by TheSubaruJunkie »
After the accident, ive come to the realization that this sedan is soaking up too much $$$. Just to get it to look good again will cost over $1,000. Ive sourced a '91 LSi Wagon, and I wanna take the EJ22T, 5spd, Exhaust and stuff it into this LSi. That would be my dream wagon.
Ive gotten different story's from "Bolts right in" to "Swap everything from fuel lines to engine harness"
I think Josh just got done with a swap like this, has anyone else done it? What am i faced with as far as engine management? Im mechanicly enclined, but electronicly stupid. Expecially when it comes to MPFI & Turbo Management.
Any insight would be greatly appreciated, thanks :)
-Brian
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
Post by BAC5.2 »
Hmm. I would guess you could do a bolt right in, but if it were me, I'd "swap everything from fuel lines to engine harness"
Just empty the LSi engine bay, power wash it, then empty the SS bay and dump it all into the LSi.
With the engine pulled, I'd detail the HELL out of the wagon. Turn it into the cleanest BF in history.
TheSubaruJunkie
Yeah, was gonna detail alittle.. the hood is faded by the CA sun. The body has some dents and scratches, but nowhere near as bad as my legacy.
-Brian
1986 Toyota 4Runner
Post by BAC5.2 »
Hmm, since your Turbo hood is still in decent condition, you should use it as a mold for a custom hood.
A good shop could fab you a carbon fiber hood, or you could even just lay it in fiberglass yourself.
One of these days, I'll be brave, and make a fiberglass hood, or have my hood cast in Carbon Fiber. Our hoods are SO heavy as it sits, there's a lot of weight to be saved.
And you could paint it to match (I'd DEFINATELY paint a carbon fiber hood. Unless it's black, raw carbon hoods look ugly).
Search back for MK's threads about his EJ22T swap.
It will bolt right in, but you need some things from the 92 in addition to the engine, like:
The sensor and solenoids on the passenger side strut tower.
The crossmember and exhaust components.
The MAF sensor, if the 91 is a 4EAT.
The ECU.
The fuel pump.
That's not an exhaustive list, but it's a start.
You're keeping the entire engine together (heads, manifolds, etc), right? So you'll already have the turbo fuel rails and injectors.
The wiring itself is pretty easy. You do not need to swap the entire turbo harness into the non-turbo car. You actually want to swap the non-turbo engine harness (the harness attached to the intake manifold) onto the turbo engine, and then just add a few wires and switch a couple wires. Look for a thread called "Problems wiring the swap" by MK for the details.
TheSubaruJunkie
THanks VRG. I will have my 92 as a parts car, so everything will go across. And Im most definatly keeping my exhaust. Just hope it bolts up the same.
Im not worried about my hood. I want to get a very small scoop to put over the turbo, and retain the chiminey. Other than that, the standard hood will do.
I found the car today i think. Its a '91 LSi wagon with some underbody damage (unseen to the naked eye). Grey and faded paint. Perfect grocery getter :)
-Brian
1986 Toyota 4Runner
Matt Monson
Post by Matt Monson »
What you will want to do is get the wires needed for the boost solenoid, pressure sensor, etc (basically the whole sensor cluster from the passenger strut tower) from the turbo harness. It should take you about 3-4 hours to remover the dash, heater and pull the harness out of the chassis and then another 4+ to strip them out of the turbo harness. You only need the main bulkhead harness, not the engine harness that runs down the driver's side fender. As VRG mentioned, you can switch the NA engine harness over to the turbo engine and just plug it in.
The only thing you will need to do to switch ECU's is plug in those wires from the Boost S/pressure S and to switch the cam angle sensor and crank angle sensor wires on the ECU. For some strange reason Subaru reversed the placement of these two wires between the NA and Turbo cars. Otherwise, the wiring is identical.
Can you do me a favour? I found that the 17.5" turbo radiator would not fit in my '90 wagon. Will you measure you '91's chassis and see if the frame sits lower and could accomodate the turbo radiator? You will want to use this radiator if you can as it will cool slightly better than the NA one, and it will already be pulled out when you pull the engines...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
TheSubaruJunkie
Yeah, if I do the swap i'll definatly be using my radiator. Not only cause its bigger, but I just spent $230 for a brand new radiator not more than 2 weeks ago. So yeah, its going with the conversion.
I think im leaning more toward purchasing a '92 Turbo Wagon, and doing a 5spd swap instead of a whole EJ22T swap. Might be alot easier, and i already found a buyer for my current EJ22T so that will help purchase the Wagon if I can find one.
Thanks for all the info guys... this is much apreciated. Has answered pretty much every question ive had.
-Brian
1986 Toyota 4Runner
georryan
Post by georryan »
Where are you going to find a turbo wagon?
So your going to sell your car completely?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
Post by entirelyturbo »
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Matt Monson
TheSubaruJunkie wrote:Yeah, if I do the swap i'll definatly be using my radiator. Not only cause its bigger, but I just spent $230 for a brand new radiator not more than 2 weeks ago.
-Brian
But will it fit was my question! :?:
Suby Hai!
TheSubaruJunkie
I'll make it fit Matt :)
Ryan, thats a plan. I dont feel like driving to Utah or spending 4k on another car. So i doubt that will work out SubyLuvr.
-Brian
1986 Toyota 4Runner
Matt Monson
:evil: Jesus man! You don't get it, I want to know so that we can provide this information to future swappers. Is it so hard to go out to your car with a tape measure and spend five minutes for the good of the board members? :idea:
Suby Hai!
TheSubaruJunkie
Damn dude... calm down. if its demensions you want, just goto www.radiators.com and look up a EJ22T radiator. They provide you with the WxHxL in dementions.
I dont have an LSi wagon to compare with. I do have the old radiator of mine in my garage, and if it really means that much to you I can go take measurements.
But back to the frikken topic!!!! Thank you. :x
-Brian
1986 Toyota 4Runner
Matt Monson
TheSubaruJunkie wrote:Damn dude... calm down. if its demensions you want, just goto www.radiators.com and look up a EJ22T radiator. They provide you with the WxHxL in dementions.
-Brian
Dude,
I am not pissed, just annoyed that you took three posts to say that you can't take the measurements. Was it so hard to just say that you didn't have the car handy?.Instead you wanted to play the smartass and say "i'll make it fit" I will repeat since you seem really dense: I have both radiators! I have measured both radiators. I was looking for the dimensions of the engine bay. thanks for nothing but a crummy attitude. Generally we try and help each other around here but hey, if you don't want to help out the group, that's your deal. Now I will leave and let you return to your precious little thread...
Suby Hai!
TheSubaruJunkie
If you paid any attention at all, you would have realized I didnt have the car in my possession. But still, you insist that i go out and measure the engine bay of a car i dont even have. Finally had to get an attitude to get you to understand.
So now that we're on the same level, lets let bygones be bygones and get back to the subject.
I doubt im going to try the conversion. I'd hate to take a good running EJ22T and butcher a good running LSi to try to frankenstein something. I think i'll just sell off my EJ22T as parts, and use the $$$ to get a straight Legacy.
Matt.... dont they have junkyards there? Maybe there's an L there for you to measure. And if I really wanted to be a smartass, i would have been ;P
-Brian
1986 Toyota 4Runner
