Page 2 of 4
Re: Silinc3r's 05 Legacy GT with more Spec B
Posted: Wed Oct 16, 2013 4:29 pm
by cj91legss
Stupid Japan.....
Posted: Thu Oct 17, 2013 3:39 am
by beatersubi
Thanks Mike. For some reason I thought Tony had said somewhere that his was a Spec C.
Posted: Thu Oct 17, 2013 3:41 am
by SILINC3R
beatersubi wrote:Thanks Mike. For some reason I thought Tony had said somewhere that his was a Spec C.
Noooooooo
Posted: Thu Oct 24, 2013 3:41 am
by SILINC3R
Ok pictures are up. Spec B 2006 Red Brick Leather seats. I now have a unicorn SWP 2005 GT. They only made these seats for the 2006 model Spec B.
Spec B rims also!
JDM STi Genome grill
Also have JDM Aero Spats that will need to be put on later. Lucked out on the grill and it was already SWP so I jumped on it. The spats will need to be painted.
Posted: Thu Oct 24, 2013 3:47 am
by SILINC3R
Posted: Thu Oct 24, 2013 5:46 am
by dankberries
Crown Royal bag shifter boot?! That is sweet!!
Posted: Fri Oct 25, 2013 6:09 am
by CFK
WOW ! So Nice
That looks like Euro Fit & Finish !
The Grill looks aggressive< maybe to Aggressive
( IMO )
Very Nice Car
Posted: Mon Nov 18, 2013 3:30 am
by SILINC3R
Thanks for the comment guys. Yea not to sure of the grill yet. But it is something different. Kind of reminds me of a boar.
So over the weekend I finally had the time to do the suspension swap to the BC BR coilovers. Had issues initially with hardware being seized so I just bought all new hardware.
And so I would never have problems again I used the same techniques I use working on aircraft.
And this was odd, notice the difference
Finished
Still have a little fine tuning to do. Lowered the height in the front again today.
Posted: Mon Nov 18, 2013 6:39 pm
by beatersubi
Is that spray-on anti-seize?
Are you adjusting by corner weight or visual ride height?
Posted: Tue Nov 19, 2013 6:56 pm
by SILINC3R
It is a spray on corrosion inhibitor. Really great stuff. Right now it is visual, i would like to corner it in the future.
Posted: Mon May 05, 2014 6:27 am
by SILINC3R
Well here's your problem
Posted: Mon May 05, 2014 5:41 pm
Yup....that'll do it
Posted: Fri Aug 22, 2014 1:17 am
by SILINC3R
Alright so BIG update 8/21
Repaired and painted the Spec B rims, rebuilt and painted stock rear calipers and Brembos. All 4 rotors turned and new pads installed with Stoptechs. H&R 15mm spacers with extended studs installed as well. Muteki lug nuts.
On a side note I have a 90 Miata with no ABS and a 91 Legacy Turbo. When I bled the brakes I did it like 3 times because I had forgot what the LGT brakes felt like, mushy. I was like this can't be right but that is how they are.
Kind of gives you an idea of the extreme colors.
New boots
Stock rear caliper bracket bolts
Turned rotors for the Brembo fronts. Same size as the LGTs but the contact area is larger.
Should have stuck a ruler next to this. Using closed lug nuts.
Re: Silinc3r's 05 Legacy GT/SpecB update 8/21
Posted: Fri Aug 22, 2014 1:39 am
by mike-tracy
You and your cool parts, Tony! so...uh....I can haz your old LGT rear calipers?
Posted: Fri Aug 22, 2014 3:17 am
by SILINC3R
mike-tracy wrote:You and your cool parts, Tony! so...uh....I can haz your old LGT rear calipers?
I didn't upgrade the rears just the fronts
Posted: Fri Aug 22, 2014 2:17 pm
by mike-tracy
Ooooo... I gotcha. Front brakes look good.
Posted: Fri Aug 22, 2014 11:33 pm
What paint did you use to paint the wheels? I like
Posted: Sat Aug 23, 2014 12:51 am
by SILINC3R
Legacy777 wrote:What paint did you use to paint the wheels? I like
The rims were
Cleaned
Sanded
Bondo'd
Sanded
Cleaned
Primed
Black gloss base coat
Colorshift paint
Clear coat
Galaxy Blue
Posted: Sun Aug 24, 2014 10:35 pm
Cool!
Posted: Mon Oct 06, 2014 12:46 pm
by SILINC3R
So instead of going out with friends on a Saturday night I decided to spend 12 hours working on the interior of the car! Finally installed some gauges with the cubby pod. AEM UEGO wideband and Prosport Halo boost gauge. I also installed an air filter since mine never had one, cleaned up some wiring from the previous owner and installed my Spec B steering wheel. I am very pleased with the way it came out and love the location I found for the pressure sensor.
Spliced into the clock
Pressure sensor location.
Well after 10 years and 100,000 miles it finally has a cabin air filter!
Unfortunately I had to do some cutting to get the best fittment with the AEM wideband
Re: Silinc3r's 05 Legacy GT/SpecB update 10/6
Posted: Sun Oct 12, 2014 9:40 pm
Tony,
Is that pressure sensor for the boost gauge? Did it come with that little inline filter?
Posted: Mon Oct 13, 2014 6:00 am
by SILINC3R
Legacy777 wrote:Tony,
Yes sir, electronic boost gauge. And yes the filter came with it, as well as the sensor. Awesome price. Highly recommend prosport gauges.
Posted: Wed Oct 29, 2014 11:25 pm
by DLC
Lovely BL. Lots of nice parts. Unlimited is how I would have gone, but the BP instead. Too bad the market is still very strong for those rare birds.
(see signature)
Posted: Mon Mar 16, 2015 6:32 pm
by SILINC3R
Re: Silinc3r's 05 Legacy GT/SpecB update 03/2015
Posted: Mon Mar 16, 2015 11:59 pm
by Scruff_
That grille looks amazing!!
