CV joints replacement
eastbaysubaru wrote:The FSM's say that you shouldn't unstake/unlock the nut or remove it until the car is off the ground. Won't the axle spin if I try to remove the nut while the front end is off the ground? Again, Thanks in advance.
Pardon me if I'm not fully understanding the situation, but couldn't you put the car in gear and have a friend grip the wheel by the tire on the opposite side of the car while you apply torque to the nut?
eastbaysubaru
Post by eastbaysubaru »
Well, I've got air tools so that shouldn't be a problem. I'm more concerned with the seal that they talk about in the FSM's. Should it be replaced? How will I know if it gets, or is, damaged? Thanks again guys.
-Brian
'04 PSM FXT
ciper
Post by ciper »
If auto you can put the car in park and it will hold the front wheels still.
For me I jacked the car up so that the front wheel was still touching the ground but less weight was applied. I then turned the nut maybe 1/16 turn (just to brake loose) then jacked the car all the way up.
You are supposed to replace the NUT and a new axle should come with one....
eastbaysubaru
Interesting dilema, my torque wrench only goes up to 75 ft lbs and the manual says to torque it to 150 ft lbs. Is it really necessary to get it to 150 ft lbs exactly or will I be alright just tightening it as much as I can by hand? I'm not exactly sure what to do at this point. Any thoughts?
-Brian
'04 PSM FXT
eastbaysubaru
Figured out the torque wrench problem. The next problem is that the axles didn't ship with new spring pins or axle nuts. This seems to be a BIG problem because everything I've read says that you need to use new ones when you replace the axles. Is it going to be bad if I use the old spring pin/nut? Moreover, why didn't CVAXLES.com send a new spring ping/nut?
-Brian(frustrated as hell)
'04 PSM FXT
ciper
Post by ciper »
Strange, mine came with pins and nuts?
If you remove the pin from the correct side and/or spread it apart again when you are done plus make sure to install it on the right side I dont think its a problem.
The only reason they say not to use the axel nut again is because usually the spot you bent wont line up in the same place againe so you have two dents and it could come loose I guess.
I wouldnt stresss about it too much.
BTW, do you need the 32mm socket?
eastbaysubaru
Nope, I got the socket a week or so ago. I just reused both the spring pin and the nut. I hope it doesn't make a difference. I got one done tonight, but the other will have to wait until tomorrow when I have the air tools handy. The one thing I'm a little concerned about is that the axles look much different than the ones that came out. I'm not sure that it makes a difference, but it's something I noticed and wanted to bring up. Ciper, were your axles exactly the same?
-Brian
'04 PSM FXT
ciper
Post by ciper »
Hmm, I didnt really check since I did all three at different times.
I would guess that if they are diffferent it might be because they use axles from 90-96? legacy and 93-9X impreza axles mixed in possibly. Ill take a look
bonestock
Post by bonestock »
Since I started this thread... I can post again ;)
Is it possible that my Legacy is now a 3 wheel drive. Whenever I am on a slippery surface, I hear a strange noise like if something was not engaging properly to make the front wheel turn...
ciper
Post by ciper »
Is your car a turbo (lsd)? If not your car could sit while spinning two wheels
gt tankie
Post by gt tankie »
just a note on the hesitation/lack of power u r experiencing.
I've got a 92 GT legacy and was having trouble with acceleration, i.e. the further I floored it the harder the car ran(leaned out).
I put up with this for about a year and then it died, cranked but wounld not start. Turns out my fuel pump died. It's electric and sits in the fuel tank and runs at a constant rate and what is'nt used by the motor goes back to the tank. Well mine was running slower and slower hence the injectors were'nt getting enough gas which resulted in a lean run.
Of note it also killed my computer. Replaced both (NZ$1500) and it's fine.
A healthy pump should give off a quiet high pitch whine from the boot.
Hope it helps.
legacy92ej22t
Post by legacy92ej22t »
well I'm finally going to replace both my front axels this weekend,probably give the front brakes a little tlc also.interested to see if mine come with all the parts[axle nut,spring pin]i'm an axle virgin so here's to losing my cherry :lol:
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Post by entirelyturbo »
Man I don't wanna see another axle after tomorrow!!!
My axles from www.cvaxles.com came with nothing, no pins, no nuts no nothing. But I am close enough to them that I picked up my axles in person rather than having them shipped...
Thursday my friend and I planned to swap my axles, do my brakes, and fix my broken wheel stud since we're there...
Yes I know now, waaaaaay too much stuff to do in one day with only common tools. It so happens that one of my caliper bolts' head is stripped, so I'll have to have someone take that out.
Anyway, we proceeded to swap my bad axle, the one making noise and a cut boot. I can now speak from experience: You need a hammer and punch to get the spring pin out. THERE IS NO OTHER WAY!!! We tried hammering nails and other things in there to pop it out, we even ran a speedo cable through the pin and tried to yank it out. So we wasted precious time going to Home Depot to get a punch.
So old axle is now out, and we attempt to find the seal on the tranny. I stick my screwdriver in there to find it, and come up with nothing. So I took the seal that the dealer gave me, and it won't fit. I'm now really pissed, but I have 4 hours to get to work, so I figure, it didn't leak before so I won't worry about it.
After a 30 minute break, we come back out and find about a half-quart of gear oil on the ground. Apparently, my digging around with a screwdriver unclogged the gunk that was holding the oil in there.
Now it's time for me to go home and get ready for work. Against posts I've read on this board, I go get a quart of Mobil 1 synthetic gear oil to "hold me" until I can fix it...
That quart has long since leaked out, and a quart of Redline 80W140 I had left from trying to find a synchro cure has been "circulated" through the system too.
And upon revisiting the dealer Friday, I learned I do indeed have the correct seals, but my stupid ass didn't understand that they're DIRECTIONAL... :oops:
Anyway, I should probably get to bed since I'm taking the whole day tomorrow to fix the thing myself.
I'll be back with an update, and a review for cvaxles.com, after I (supposedly) fix it...
*Formerly DerFahrer*
eastbaysubaru
My cvaxles.com axles didn't come with shit either. I even called them and asked what was up since Ciper got his with both the spring pin things and a new nut. I just ended up reusing the parts. To get the spring pin out I used a drill bit turned around backwards. I know how frustrated you are, I have been there and back. The problem I ran into was that one of the axle nuts was on soooo tight that I couldn't get it broken loose. I had air tools (not burly enough), a breaker bar with a four foot attachment and my 200+ lb. ass. I ended up having to take it to a shop where they broke it loose and tightened it back to the correct spec. PITA!!! I hope it all works out well for you. Don't get down on yourself, just chalk it up to added experience under the belt :wink:
-Brian
'04 PSM FXT
legacy92ej22t
ok so what a freaking nightmare,first i couldnt unstake the axle nut because none of the 6 punches i have were small enough to get under the punched part of the nut :x so 4 stores and 2 hours later i have what i need,but i missjudged my strength just a wee bit cause i couldnt break the nut loose with my 1/2 " driver,thought it was long enough for leverage,wasnt.so off to get a breaker bar.ist i go to sears cause i have a card there,they only have 1 and its 30$ :shock: no way,so i go to a pretty cool place here called surplus city,has discount tools.get an even nicer bar 9.95$ok so another 1.5 hrs past i figure im in bussiness.both nuts break loose so im stoked and start on passernger side go's like butter.axle pulls out of hub by hand,spring pin was a little tricky cause once again i didnt have proper punch,but i was able to get it 3/4 the way out then used small round file to push it out.axle comes right out of differential.damn nothing to it i start thinking.move on to driver side,get the control arm stabi. bar unhooked go to take axle out of steering knuckle and it wont come out.ok no problem ill use hammer and punch,nope actually bent my heavy duty punch :evil: now im starting to get pissed,back to the store for a 2 jaw puller.get the puller put it on start pulling and the axle just wouldnt pop out the middle part of the puller is actually boring into the punch hole on the axle and it still wont pop :shock: so im having to use a pry bar to hold the hub while im turning the puller and i break my tone wheel :cry: so now im really upset so i keep torking on the puller and it finally explodes 12.95 down the drain.does anyone know what i should try next?i know i have to remove the steering knuckle now to fix the tone wheel so should i just take the knuckle and axle to a shop and have them get it out?someone help please,thanks
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Wow, we have the same problem, your driver's side is tougher...
I am pretty pissed at my car right now. As posted last night, I was going to put an axle seal in today... No such luck. I ruined the seal trying to get it in. Probably a mix of improper tools and not enough room in engine bay. So I put the right side back together, and squeeze half a tube of silicone gasket sealant in there in desperation.
While that's curing, I decide to try the driver's axle. That balljoint was much more stubborn, and a little rusty. But my passenger's balljoint is fairly new, so that's why. Anyway, so the balljoint is separated from the knuckle, and I pull the knuckle away from the axle. It won't budge, again this worked on the passenger's no problem. However, I took a piece of wood and a hammer and eventually pounded the axle out of the hub, slowly but surely. So after complaining that I had to do the whole pin thing from under the car, since that pesky starter is in the way up top :lol:, I got the new axle in.
The balljoint was even more stubborn coming back together. I eventually had to work as much of it into the knuckle as I could with a flathead screwdriver, and then jack up the control arm against the strut to force the balljoint back into the knuckle.
And no the silicone didn't do a damn thing. Of course the stuff cured onto the axle splines, which probably pulled the whole thing right out once I started driving. So I'm still leaking gear oil all over the place. I give up. I'm takin it to the stealership...:evil:
But I do like the axles very much. They're from cvaxles.com. Read my review in the Reviews forum.
So anyway, wow you broke a freekin 2-jaw puller??? :shock: Unless you can squirt a crapload of WD-40 or bolt-loosener in there, yeah I'd say you might hafta take the whole knuckle and axle out and have someone else press it out...
legacy92ej22t
ok so i'm really pissed off right now!took the drivers side axle and the steering knuckle to a shop to get axle out and pull out hub to fix tone wheel and they couldn't get it out! :evil: they put it in a 10'000pound press and it just mushed the end of the axle :shock: so they are going to cut it out of the knuckle to try and salvage axle so i can at least get the core charge on the axle.they are going to try and salvage as much as possible but it doesn't look good.so i'm probably going to have to get a new knuckle,wheel bearing,hub,ect..the whole damn assembly.has anyone ever heard of anything like this?the guy at the shop said it was a first for him.so not much happening right now except money flying out of my wallet.i'm probably not going to have enough to do my brakes now. i would sure like to start doing mods but every time i save money something stupid breaks and eats the money :cry: i'll update soon
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Aaron's ej22t
Post by Aaron's ej22t »
when i put new boots on my axles, the passenger side axle shaft came out of the hub no problem. but, the driver side would NOT come out. we tried for 2 hrs and finally took off the whole brake/hub assembly from the car.
92 Legacy Turbo \ 5MT \ Silver
legacy92ej22t
allright,torched out the axle so i got the core charge but i lost the wheel bearing.so i got the axles and they have everything in them,new axle nuts and pins.i got the driver side back together last night,steering knuckle wasn't too bad but the axle was a pain to get in,had to pound it in with a board[being very carefull not to damage anything]ball joint gave me some pain to,seems everything is real tight.oh ya the shop that pressed my hub and wheel bearing together had a lot of trouble with the seals to :x they destroyed a couple sets before finnally giving up.the auto parts store gave me the wrong ones.they had it wrong in thier computer.so they give me the right ones and i take them to the shop.the outside went together allright but the inside wouldn't,so back to the auto parts store i go but this time i take the old one which is much thinner.ends up they had to give one for a loyal and it worked.antways back to the axles,got it all togwether rebuilt the brakes had the rotors turned,will get gas slotted someday hopefully next time pads need change.and its looking good.doing passenger side today which should be easier cause it came apart real smooth.cant wait to drive my baby again will update later
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
ciper
Post by ciper »
Why dont you use parts from the dealer? (except for the axle) You wouldnt have had as much trouble and you are sure to get the latest revision. Those aftermarket bearings could be of the old design and will fail after a short amount of miles!
legacy92ej22t
unexpected problems were over budget had to go economy style :) did the other side yesterday went super smooth maybe .5 hrs with brake job.had enough time that i put new rotors and pads on my friends 93L sedan for him.didnt have time for a real test drive until tonight when i got home from work.she runs great!super smooth, braking is consistant,smooth and solid.its so nice not to clunk around corners.stoked at last.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Brat4by4
Stratified
Post by Brat4by4 »
Hate to spoil it for the hardcore Do-It-Yourselfers, but... this is how axle work goes for me.
Drive in. Pay for new axle with lifetime warranty + install.
Drive away. Any more problems with any purchased half-shaft and they are stuck screwing with it for the rest of my life.
5 new half-shafts went on the exact same wheel of my Brat this way.... Boots kept ripping apart (no shadiness or off-roading on my part), oh well, they dealt with it.
ciper
Post by ciper »
"economy style" I doubt the dealer parts are any more expensive than the generic stuff. Check the price list in the first forum and then enter those into subaruparts.com
legacy92ej22t
subaru's price was around 80$US, got mine for 38$US.seals were close,I saved maybe 4$ on them.trust me I'm usually a quality over quanity type guy but I was not expecting to loose the bearing in the first place or have a shop torch and air hammer my axle out of the steering knuckle.so take into account 1-had to get a new tone wheel[35$ used]2-new wheel bearing and seals[around 58$]3-shop time on my axle and repressing my hub/wheel bearing[45$]4-gas running all over hell and back trying to get good deals[around 10$v8 pickup doesnt get the suby mileage]5-destroying 6"2 jaw puller[13$]6-the horrible depression I experienced from not driving my baby for 2 weeks :( [my shrink will bill me later] :) so as you can see i was severly over budget.all above money was money i didnt have.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
michael888us
Post by michael888us »
i have the same problem with the rear cv axle ,i got the pin out ,axle nut off but the axle still stay in the hub ,i tried the hub puller ,big ass hammer,it still would give up,so i am thinking to remove the whole assambly,anyone know how to take off the rear parking cable off the rotor?
