Ej20G- Front injector connectors (#1 & #2) are made from light grey plastic. Rear injector connectors (#3 & #4) are made from dark grey plastic.
That flywheel needs resurfacing.
Got it! So you're saying pull the canister purge solenoid from the EJ22T and mount it on the EJ20G without plumbing it?PhyrraM wrote:Your "??????" is for the canister purge solinoid on the EJ22T manifold. I don't believe the EJ20G has it (in most contries). I think you will throw a code without it on the EJ22T ECU. If you do get a code, just plug it in and bolt it to a convienent bolt but don't try to plumb it in.
The "something on block" most likely goes to the oil pressure sender near the crank pully.
Yours is a '91, correct? I know the main plugs @the battery area are different on the '92+, but I had one more connector with ONLY grounds on it. Does your also have that?
Don't forget to swap your crank and cam sensors for the Legacy ones also. They plug into the back of the block.
I'm not sure what exactly I'm going to do. I like SlowDrive's bracket also, but I don't have the fabbing skills to replicate it. I'm probably going to order from Magnecor and get some custom lengths, regardless.PhyrraM wrote:Valve covers look good. What do you have planned for the coil? Mine is just ziptied up off the alternator post ATM. Planning a bracket similier to SlowDrives.
I've been using Livestrong14's swap thread(s) as a reference from the start, actually. I love his car so much!PhyrraM wrote:If your going to order custom wires, search out some of Livestrong14 (?) old posts. Before he did the USDM swap he was running an EJ20G and I seem to remember his coil being mounted nicely also.
Cheaply constructed headers would likely crack if heat wrapped.Fkyx wrote:You make a good point. I was planning on wrapping whatever manifold I end up using, anyway. Do you think that'd make up for the possible heat issue in ebay headers/uppipe?
That they are! Cost me $243 shipped without tires from a guy in Texas. Running Toyo Proxes 4 215/45/17 at the moment.asc_up wrote:Are those the JDM BD/BG rims? Let's see pics of them on the car!
