Legacy Final Drive Ratios
Todd A Erickson
LEGACY
MT
clutch
AT
turbo MT
clutch
turbo AT
1990 leg
4.11
cable
4.11
1991 leg
4.11
cable
4.11
3.9
hydro
3.9
1992 leg
4.11
cable
3.9
3.9
hydro
3.9
1993 leg
4.11
cable
3.9
3.9
hydro
3.9
1994 leg
4.11
cable
3.9
3.9
hydro
3.9
1995 leg
3.9
cable
4.11
1996 leg 2.2
3.9
cable
4.11
1996 leg outback 2.2
4.11
cable
4.44
1996 leg 2.5
N/A
N/A
4.44
1997 leg 2.2
3.9
cable
4.11
1997 leg 2.5
4.11
hydro
4.44
1998 leg 2.2
3.9
cable
4.11
1998 leg 2.5
4.11
hydro
4.44
1999 leg 2.5
4.11
hydro
4.44
2000 leg 2.5
4.11
hydro
4.11(L)/ 4.44(GT)
2001 leg 2.5
4.11
hydro
4.11(L)/ 4.44(GT)
90-94
sport
1st
3.545
3.545
IMPREZA
MT
clutch
AT
2nd
1.947
1.947
1993 imp 1.8
4.11
cable
4.11
3rd
1.366
1.366
1994 imp
4.11
cable
4.11
4th
0.972
0.972
1995 imp
4.11
cable
4.11
5th
0.738
0.738
1996 imp 1.8/2.2
3.9
cable
4.11
final
4.11
3.9
1997 imp 1.8/2.2
3.9
cable
4.11
1998 imp 2.2
3.9
cable
4.11
95-99 2.2
98-99 2.5
1998 imp 2.5
4.11
hydro
4.44
1st
3.545
3.545
1999 imp 2.2
3.9
cable
4.11
2nd
2.111
2.111
1999 imp 2.5
4.11
hydro
4.44
3rd
1.448
1.448
2000 imp 2.2
3.9
cable
4.11
4th
1.088
1.088
2000 imp 2.5
4.11
hydro
4.44
5th
0.78
0.871
2000 imp 2.5 RS
4.11
hydro
4.44
final
3.9
4.11
2002 imp 2.5
3.9
hydro
4.11
2002 imp WRX 2.0
3.9
hydro
4.11
*3.9 front, 1.1 transfer reduction to 3.545 rear
FORESTER
MT
clutch
AT
1998 for 2.5
4.11
hydro
4.44
1999 for 2.5
4.11
hydro
4.44
2000 for 2.5
4.11
hydro
4.44
SVX
AT
1992 SVX
3.545
96-99 Legacy 2.2
3.9
cable
96-00 Impreza 1.8 - 2.2
3.9
cable
97-01 Legacy 2.5
4.11
hydro
98-01 Impreza 2.5
4.11
hydro
02 Impreza 2.5
3.9
hydro
MT
clutch
AT
turbo MT
clutch
turbo AT
1990 leg
4.11
cable
4.11
1991 leg
4.11
cable
4.11
3.9
hydro
3.9
1992 leg
4.11
cable
3.9
3.9
hydro
3.9
1993 leg
4.11
cable
3.9
3.9
hydro
3.9
1994 leg
4.11
cable
3.9
3.9
hydro
3.9
1995 leg
3.9
cable
4.11
1996 leg 2.2
3.9
cable
4.11
4.11
cable
4.44
1996 leg 2.5
N/A
N/A
4.44
1997 leg 2.2
3.9
cable
4.11
1997 leg 2.5
4.11
hydro
4.44
1998 leg 2.2
3.9
cable
4.11
1998 leg 2.5
4.11
hydro
4.44
1999 leg 2.5
4.11
hydro
4.44
2000 leg 2.5
4.11
hydro
4.11(L)/ 4.44(GT)
2001 leg 2.5
4.11
hydro
4.11(L)/ 4.44(GT)
90-94
sport
1st
3.545
3.545
IMPREZA
MT
clutch
AT
2nd
1.947
1.947
1993 imp 1.8
4.11
cable
4.11
3rd
1.366
1.366
1994 imp
4.11
cable
4.11
4th
0.972
0.972
1995 imp
4.11
cable
4.11
5th
0.738
0.738
1996 imp 1.8/2.2
3.9
cable
4.11
final
4.11
3.9
1997 imp 1.8/2.2
3.9
cable
4.11
1998 imp 2.2
3.9
cable
4.11
95-99 2.2
98-99 2.5
1998 imp 2.5
4.11
hydro
4.44
1st
3.545
3.545
1999 imp 2.2
3.9
cable
4.11
2nd
2.111
2.111
1999 imp 2.5
4.11
hydro
4.44
3rd
1.448
1.448
2000 imp 2.2
3.9
cable
4.11
4th
1.088
1.088
2000 imp 2.5
4.11
hydro
4.44
5th
0.78
0.871
2000 imp 2.5 RS
4.11
hydro
4.44
final
3.9
4.11
2002 imp 2.5
3.9
hydro
4.11
2002 imp WRX 2.0
3.9
hydro
4.11
FORESTER
MT
clutch
AT
1998 for 2.5
4.11
hydro
4.44
1999 for 2.5
4.11
hydro
4.44
2000 for 2.5
4.11
hydro
4.44
SVX
AT
1992 SVX
3.545
96-99 Legacy 2.2
3.9
cable
3.9
cable
97-01 Legacy 2.5
4.11
hydro
98-01 Impreza 2.5
4.11
hydro
02 Impreza 2.5
3.9
hydro
Todd A Erickson
I work at a automotive technical hot line. When that technician at the local repair facility needs information or assistance in diagnostics, I’m the guy he might call. It is a subscription service for professional repair facilities.
I specialize in Asian imports.
I’m a Sr. Master Subaru Technician.
Within easy reach, I have the factory manuals from 1980 to 2002-2003 for all Asian makes.
Todd Erickson
<http://www.identifix.com/> http://www.identifix.com/
Todd Erickson
Josh Colombo
Todd,
Welcome to the list. Glad to have someone of your background perusing around
If you want, check out www.bbs.legacycentral.org It's essentially an extension of this list. We sorta out grew the initial yahoo setup and wanted more, so that board was created. Most have moved over to the board, however myself and others still keep at things on this list as well.
Rob Haylock
Hi Todd,
Holy crap!! Would you have the FSM's that cover the JDM 1991 Legacy
RS? RS as in EJ20 turbo/intercooled?? I'd give my left testicle
(almost!) to get hold of a set of them.....I've contacted my local
Subaru dealer (no joy) & have even written directly to Subaru in
Japan - got a very polite but negative reply....so I'm almost at my
wits end!! It seems you can get some sort of manual for every Subaru
EXCEPT the RS 2.0 turbo/intercooled model...
Waddya reckon, can you help any??
Cheers,
Rob
Cheers,
Rob
Todd A Erickson
All I have is domestic (American).
I think Australia could be the source for your manual.
Todd Erickson
Total Performance Center, Inc.
"Todd the tuner. Can he tune it? Yes he can!!!"
Servicing the Minneapolis MN area.
Todd Erickson
Rod_
Not sure about your US Legacy's but the Aus RS Liberty diff ratio is
not so simple...
-The RS use a 3.54 diff at the rear and 3.9 on the front. They use a
1.1 :1 center diff stepper in the gearbox , this gives them mostly
front wheel drive , if you X 3.54 X 1.1 = 3.9
cheers, Rod
not so simple...
cheers, Rod
Nick Robinson
Rod
Something I've been meaning to ask you about this. Is it possible to
reverse this FWD bias using different front and rear ratios, or could
you just even it up by using 3.9 at the rear and a 1:1 center diff?
Maybe that will screw up what is essentially a pretty good setup but I
grew up on a diet of RWD and enjoy oversteer more than understeer!
Rod_
hey , good question. I would prefer the 1:1 centre diff then 3.9 rear so all is the same. Then create a little oversteer with suspension setup. Even as it is my car is quite neutral and can tend to a little over steer only using a 22mm rear bar and upgraded front links to help turn in. It also has WRX 16" wheels with 205/55 16 tyres which also helps compared to the std.
Rod
Rod
Todd A Erickson
The Aus RS Liberty (approximately a USA Legacy Sport) sounds like it is geared like the 01 USA market WRX.
Side note; That is the reason I think the WRX MT is a good fit to a SVX (also has a 3.54 rear)
Todd Erickson
Todd Erickson
Todd A Erickson
Actually it works out to a 3.90 front and rear. The transfer ratio is 1.1 to 1 and the final drive is 3.54 to 1. So 1.1 times 3.545454 (actual ratio) is 3.8999994.
Todd Erickson
Todd Erickson
Rod_
soory Todd - are you refering to my email? if so, yes that is what i wrote.
the fact there is a diff stepper in the box means the front (3.9:1)actually turn faster than the back (3.545:1)but the 'overall' ratio is 3.9.
Rod
Rod
Rod_
these ratio's were used in all the Aus WRX as well, up to MY01. (STI different) The MY02 has different gearing now.
Rod
Rod
