air conditioning air
where is the vent or the intake to our air conditioning system, is it easy to get to ?
92 legacy turbo 5spd fwd-12 psi, tm intercooler bov, walbro 255.
81 chevy malibu- 400 sb, holley 600, edelbrock rpm, hooker headers, lunati voodoo cam,4spd muncie, 3:73 posi,monte c. swivel buckets, corvette rally wheels
On any setting but "MAX A/C" it pulls it in from the outside right under the windshield wipers... You will see the grid if you look... On "MAX A/C" it pulls the air from behind the glove box. The glove box can be removed with two bolts allowing access to the "MAX A/C" intake (pretty easy)... As for getting to the intakes, if all you are doing is looking for the very beginning of them, then it should be pretty easy.... but it depends on what you are trying to do....
Andrew
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
