Exhaust Recommendations Please....
Soarer
Post by Soarer »
I've got a 91 SS and I'm considering upgrading the exhaust. I'd like some recommendations from you long time subi experts as to what I should be looking for.
I don't like loud rattle traps and I hate those coffee can mufflers. I'd like a stock look and bit more tone and grumble from the system. Also, I'm considering doing a small turbo upgrade in the future so I'd like something that will bolt right on to the stock set up and accept a mild subaru turbo upgrade later.
Last but not least, should I be doing headers? I'd like to save the expense and not do them but am open to suggestions. As you can guess, I'm on a tight budget so $650 systems aren't an option. What I'm hoping to hear is that I can take a WRX system that is bit bigger than the stock SS pipes and then put a test pipe and aftermarket muffler on there to top it off.
Sold :-( My 1991 Sport Sedan EJ22t 4EAT
WRX Seats, K&N Panel Filter, 3" Turbo Back Exhaust
Current Subi: 1998 Legacy GT Wagon 5sp in the midst of an EJ257 STi swap with 6sp. Woohoo!
dscoobydoo
Post by dscoobydoo »
3 inchdown pipe ( from a WRX) full 3 inch exhaust with a resonator and a dual tip exhaust muffler. Sounds good ( I could have picked up a larger muffler to make it quieter) and opens it up for performance.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Soarer
Post by Soarer »
Is that a catless downpipe from a WRX? What year? Also, did your exhaust show bend the exhaust for you or did you get it off another car?
dscoobydoo
bosal downpipe from a WRX. No cat in the pipe. A high flow cat just after the downpipe. A resonator after that. The shop ordered the muffler I wanted. ( Magnaflow) and fabbed everything after the downpipe to the muffler with 3 inch pipe.
05 GD-STI
00- GF
206er
Post by 206er »
how much did that exhaust run you
dscoobydoo
down pipe=$300
Muffler= $150
resonator = $40
cat+ install= $600
05 GD-STI
00- GF
Soarer
Post by Soarer »
Damn! That's a lot of cheddar for an exhaust.
Is it worth buying a used STI exhaust and making it work? If I can get it for $200 then it might be, right?
azn2nr
Post by azn2nr »
stock exhausts are just a waste of money. save your pennies and get a greddy sp2 and mod it to length. their ~500 for a catback new and every so often they come up used. not often though because alot of poepl like the coffecan invidia's
i might have an invida cast downpipe with o2 sensor bung (2 bungs actualy) in the correct spot for sale in a few months and i already have a bolton (for the most part) turbo upgrade for sale too
-jason
dscoobydoo
If you want to go cheap but good, then yes, get a used STI exhaust and have a shop modify it. Check NASIOC classifieds.
I wanted something custom, so I was willing to pay the grand.
05 GD-STI
00- GF
HellBinder
Post by HellBinder »
Here's a pic of my WRX Blitz Nur Spec next to my OEM exhaust, its not an SS-and its a wagon but there is alot of little things that have to be tweeked to make it fit close, with good ground clearance.
knuckling down and buying a direct replacment like the SP2 saves alot of heart ache and reliability issues.
Horsepower is horsepower, the label on the box doesnt matter.
94 RHD wagon,WRX swap.HKS,Blitz, ACT and a Tape player!
turboleg
Post by turboleg »
Well I found a Ghetto style of making a stock turbo exhaust sound nice.
Remove the two screws from the mid pipe and axle back and remove the gasket. Cut a small portion of the bottom of the gasket out like this:
I found this out when swapping in my EJ22T - I really wanted to drive it but didn't have a good gasket (the bottom part was missing). If its just sound your looking for that will do it (I'm doubtful there's any horse power gain at all). It passes a little exhaust at low RPM and at high RPM more exhaust passes throught the muffler. In other words at low RPM you have nice rumble sound (sounds nice going through town - but not rattle your brains out loud) but when you stomp on the gas it sounds just a little louder than stock.
Plus your total cost is probably only the cost of the two bolts and nuts you have to replace doing it...and maybe some gasket material if yours is completley rotted away.
If you have problems with inspection (emmisions) you only have to replace a couple dollar gasket that way.
Like I said it's ghetto...but it does work. Your muffler might take on a little more moisture and dirt but I didn't have a problem for the 6 months I ran like that. Since you want to replace it anyway this might curb your cravings while you save your pennies.
- Findlay
http://www.toolsource.com
Radial GT1
Post by Radial GT1 »
^ This is great stuff
00 Camry; No wrenchin', just drive. Thank you Japan!
93 Legacy SS 4Eat 96K; All the wrenching I could ask for.
[quote="un-named"]What a man & a woman, and another man with a sheep & a midget want to do is their own business...[/quote]
tonflo
Post by tonflo »
Anyone know the correct part # for the Greddy sp2 or what year, make & model car is closest to ours? Will it fit a wagon without too much difficulty? There are currently Sti/ WRX ones on ebay. Also one for a '05 Legacy GT wagon. Anyone know how good a fit either of these is for a '94 wagon?
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
turboleg
Post by turboleg »
Radial GT1 wrote:^ This is great stuff
Great for the price anyway. :D
- Findlay
ej22t kid
Post by ej22t kid »
yea using the exhaust for a WRX works after a few mods but they never fit just right.
i plan on getting a twin tube down pipe and fabbing the rest out of stainless 3", v clamps, high flow cat and mind u a quiet muffler for the sleeper, tack it up with a mig and finish with the tig.
(91 turbo sleeper to be)- RIP
I miss my legacy :(
Lee MD
Post by Lee MD »
I just installed an sti muffler on my 97 lgt wagon. it took some modding by the shop, but they did a great job to make it a bolt-on unit so i can remove later when i sell the car and reinstall the stock exhaust. the sound takes a little getting used to since i've been drving in relative silence for years since i had my Impreza RS. I can take pix if anyone is interested.
rallyryder
Post by rallyryder »
im running a perrin downpipe 3 inch all the way back no cat with cobb muffler it all came on the car when i bought it a few months ago, what can we do as far as headers and uppipe for these cars? i have a 92 ej22t
New92
Post by New92 »
STI turbo back, both cats, no muffler. Very signature subaru sound.
1992 SS 5MT
She's growing faster in her old age!
Arctic Assassian
Post by Arctic Assassian »
turboleg wrote:Well I found a Ghetto style of making a stock turbo exhaust sound nice.
You know how to make your turbo work better? Clip half of the fins in the inlet off so it will spin faster and create more of a vortex in the intake...
Kickin' it old-school.
ciper
Post by ciper »
LOL awesome. I had something similar on a Ford Escort where the bottom of the muffler rusted through.
Wasn't there a thread a while back about simply removing the gasket to get a louder boxer rumble? I seem to remember THAWA's name, but I'm not sure...
