»  BC-BF Legacy Discussion »  Misc
#Project update...GT35R, new chassis etc.
Custom Search
Login | Register
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
Author Message
 Post subject:
PostPosted: Tue Nov 06, 2007 12:44 am
A picture from the night it sheared the rear axle...
After breaking axles, a rear end, and getting rained out on previous attempts, the planets aligned Saturday. I went back to the track with my new pro level rear axle/hub setup from DSS and got my first ten second pass. I went on to run several 10.4-10.5 passes as I got used to dragging the car.
My best pass for the day was:
The car has more in it. I need to practice getting into 5th gear a lot. It's very awkward and I'm really slow at it so my 1/4 mile ET and trap are suffering.
My rear tires are spinning on the rims and the tires are spinning on the track as well so I'll need to screw them before I try to go bigger. With that done, lower tire pressure, some seat time, and then more boost, I'm confident this baby has real low 10's in it.
Some vids:
6.68/10.48 pass (in car):
http://www.youtube.com/watch?v=jxm7KRvv3l0
6.9/10.7 pass. It was early in the day and not a great pass but funny to see a Z06 get OWNED (out of car):
http://www.youtube.com/watch?v=a81adXrzxFw
10.5 at 130 against a 10.6 at 127 muscle car. Awesome drag race (out of car):
http://www.youtube.com/watch?v=qFh8MvvU8nM
and a preview of the video a local guy took:
http://videos.streetfire.net/video/d5fdb31a-5ce8-4238-a6db-99db014aa6d3.htm
Profile  Offline
 Post subject:
PostPosted: Tue Nov 06, 2007 12:57 am
Good to see you whoopin' some ghey muscle car ass!
1985 Audi 4000S quattro w/ turbo
Profile E-mail Offline
 Post subject:
PostPosted: Tue Nov 06, 2007 1:03 am
Sweeet. :). That's simply awesome.
Lee
93' SS, 5mt swapped, 133k, not stock...
96' N/A OBW 5sp, 186k, Couple mods...
R.I.P. 93' N/A FWD. 42k of dear memories...
Profile  Offline
 Post subject:
PostPosted: Tue Nov 06, 2007 2:11 am
Sweet run but... C'mon. A firebird :( ? I wouldn't brag about that as a performance benchmark.
Seriously fast car, though.
93 legacy wagon L (TW imitator)
95 legacy outback wagon (dd)
johndrivesabox wrote:
Rally, my kyboard is brok, his has nohing o do wih h liquor.
evolutionmovement wrote:
I wish I could sprout a vagina right above my junk.
Profile  Offline
 Post subject:
PostPosted: Tue Nov 06, 2007 3:58 am
Thank God you didnt stick that motor in a Legacy, I would hate to lose my title!
Damn fast! :)
Reddevil, Awaiting new heart
90 sedan, Ej22 DOHC running, awaiting turbo
1990 wagon, EJ25 12.3 @ 116.5 FAST Family wagon
 Post subject:
PostPosted: Tue Nov 06, 2007 7:40 am
That was remarkable to see you against what was assumingly a stock 500hp Z06 and eat it right off the line. It wasn't even a race...
Jason
 Post subject:
PostPosted: Tue Nov 06, 2007 5:37 pm
Damn fast! :)
What title? I had the GT35R on the stock EJ22T in my legacy running more boost than this.
Yup I'm guessing the Z06 was stock.
Profile  Offline
 Post subject:
PostPosted: Tue Nov 06, 2007 6:58 pm
I've seen those things take off in person, so it's a really good gauge of how impressive your is. You're only like 1/2 second off the former ESX door slammer the Julie Stepan use to drive. The team had it damn near the high 9's.
Jason
 Post subject:
PostPosted: Wed Nov 07, 2007 6:23 am
Thank god you didn't leave that motor in the legacy... 'cause it would have ripped apart the old chassis. I can't wait to find a nice donor shell for my motor and other bits.
 Post subject:
PostPosted: Wed Nov 07, 2007 3:24 pm
It did rip apart the chassis in 2 days. The doors wouldn't close. That's why I moved the legacy engine into the Impreza and caged it before driving it. :)
Profile  Offline
 Post subject:
PostPosted: Wed Nov 07, 2007 9:44 pm
haha nice. Did you stiffen the impreza at all? seam welds, etc?
 Post subject:
PostPosted: Thu Nov 08, 2007 2:56 am
Legacy SS front crossmember
Impreza RS rear crossmember
6 point cage
front and rear strut braces
no seam welding yet though...
Profile  Offline
 Post subject:
PostPosted: Sat Feb 09, 2008 1:09 am
The cage is being added onto. It will be a 10 point plus a few extras.
It has Brembos all around now, the wiring was cleaned up, a custom dash plate was made for the AIM Sports dash, and my fuel level, boost and EGT gauges were relocated to the HVAC control locations.
We just pulled the engine to see how it looks. As suspected the bores shifted some causing gasket transfer side to side on the head surface. I wonder how quick it would be without the leakage. Sleeves aren't in the budget for this year so it's going back together with some new head gaskets and I'll run less boost.
Some valve seats and valve seals also got hammered when the car broke axles allowing the engine to overrev momentarily (9000+ rpm). We'll rebuild the heads again, this time with valves and seals that can take some more abuse instead of using stock. Still no porting and stock cams.
Profile  Offline
 Post subject:
PostPosted: Thu Mar 06, 2008 5:14 pm
I had not looked @ this post since the 350Z track vid was posted.
All I have to say is WOW, consistent 10 second runs are nice....
The car is a monster!!!!!
I could imagine how bad the Legacy's body flex was as my low powered car's rr door dash-light reads open on high boost (for me) runs.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
Profile  Offline
 Post subject:
PostPosted: Thu Mar 06, 2008 11:17 pm
Wow! Its nice to see someone that hasnt given up and gone with an sti block, I cannot watch the vids because Im at work, but man this is a sweet build.
so let me get this straight, 35r with stock heads and no intercooler walboro fuel pump and standalone= mid 10 sec car?
this thread is amazing.
Tim
93 Legacy SS Winestone 5mt swapped
Megan Racing Bellmouth 13psi
WRX Intercooler and Hoodscoop
JDM ej20G DOHC head swap, wiseco pistons and td04 in the making.
Profile  Offline
 Post subject:
PostPosted: Thu Mar 06, 2008 11:29 pm
Innovative Tuning wrote:
This is what it looks like to a gutted NA 350Z LOL
http://www.innovativetuningdl.com/video ... ckPass.mp4
:o HONESTLY!?
holy jeez.
i can't even describe how awesome that was :shock: :-D
93forestpearl wrote:
Keep up the good work. You'll never know what you are capable of unless you push yourself.
Profile  Offline
 Post subject:
PostPosted: Thu Mar 06, 2008 11:33 pm
how did you even do that without an intercooler?
that much boost is crazy :D
i honestly got scared watching that :shock:
Profile  Offline
 Post subject:
PostPosted: Fri Mar 07, 2008 12:08 am
I actually LOLd. That's hillarious. :)
You're mixing up different portions of the build a little. It ran 33 psi on a 35R on a stock EJ22T longblock with no intercooler. Those are the autox pics towards the beginning.
Then I put an STi longblock in it and ran 11.4 on street tires with no intercooler.
Then we added an intercooler and DOT legal Hoosiers among other things like the DSS Stage 5 rear axle/hub setup to hold it together and it ran 10.4.
Last edited by Innovative Tuning on Fri Mar 07, 2008 12:10 am, edited 1 time in total.
Profile  Offline
 Post subject:
PostPosted: Fri Mar 07, 2008 12:09 am
On the EJ22T with the 35R I ran 108 MON unleaded race fuel with meth injection and some big nozzles.
On the STi with the 35R and no intercooler it was E85 plus meth injection.
Profile  Offline
 Post subject:
PostPosted: Fri Mar 07, 2008 1:43 pm
^ I think you are in the May '08 SubieSport mag (Toronto).
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
Profile  Offline
 Post subject:
PostPosted: Sat Mar 08, 2008 2:42 am
Awesome vid!!! Serious props!
I love the Starsky and Hutch replica in the 2nd vid! haha
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
 Post subject:
PostPosted: Sat Mar 08, 2008 8:12 pm
You really need a dogbox in that thing. You'd be able to trap those speeds in 4th gear, AND cut time by shifting faster.
scottzg wrote:
...I'm not a fan of the vagina...
This will all go much easier if people stop doubting me.
 Post subject:
PostPosted: Sat Mar 08, 2008 8:50 pm
Thanks for the heads up. I had no idea. I 'll try to snag a copy.
No doubt that would shave a good amount of time at the strip. I haven't even flat shifted it on the standard box yet though. There's room to grow on the stock box.
It's an all around car so I accept the non optimal ratios at the strip and enjoy them street driving and lapping it. I still have less into this car and the whole build than the cost of the average used STi and it's enough fun as it is so I'm trying to keep it that way.
Thanks a bunch! Whenever I'm out lapping it I give rides almost the whole time if anyone is interested.
Profile  Offline
 Post subject:
PostPosted: Fri Jun 27, 2008 9:44 pm
when and where are you doing laps next? i want to spend the day in the passenger seat :lol:
this is one of my favorite subies..its turbo'd like mine except yours is WAY fast :D :D :D
1996 Impreza Outback Sport 5 speed ej22
1997 Impreza Brighton 5 speed ej18t
Profile  Offline
 Post subject:
PostPosted: Fri Jun 27, 2008 11:33 pm
i want my car to be as fast as that some day :smt040
Profile  Offline
Who is online
Users browsing this forum: No registered users and 0 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
