I have nothing to say about this, except that it's epic.
1998 Impreza L coupe...
Past Subies... 1999 Legacy L AWD, 1994 AWD L, 1992 AWD L, 1990 FWD L, 1990 AWD L. Pretty much all I drive.
Things would have to have gotten much, much more sour than that before the thought of cutting my rim would ever even have crossed my mind...
I hope he has better luck JB welding that rim back together
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
WOW!
THANK YOU glassjaw! It's been a little while since I've seen failure of this magnitude. Truly delicious
http://www.slodriveracing.com
-And more!
-And more!
wow that has to be the most epic fail of 2009
fwiw he should have tried a 50/50 mix of auto trans fluid and acetone
shake and spray. Let this soak for a minute or 2 then find the correct hex drain plug socket and hammer it in then crack it loose.
I have owned 3 VW's and never had this happen also I'm working on owning my 4th subaru
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
That's because it's not VW related at all, it's all the wheels/wheel locks, which just adds to the stupidity of the guydiesel devil wrote:wow that has to be the most epic fail of 2009
