WRX Scoop DIY Writeup
Hey Everyone. I just did my wrx scoop mod a few weeks ago and though I'd share how i did it in case anybody cares.
1. First i started by removing my hood and setting it on saw horses.
2. Next i made marks with red sharpie where the center of the current scoop was located. I went for a "cross-hair" look.
3. I put a ruler on the matching lines (the horizontal cross-hair and the vertical) and extended the sharpie so i could see them with the new scoop since its got a bigger footprint.
4. Once i got the lines to match the center of the new scoop, i traced the new scoop on to my hood. (i had to remover wrx hardware so scoop could sit flat)
5. Went and bought me a Dremel since my first air tool didn't do the job. (you can see in the picture the first 6" of the cut is thicker. Dremel cut was much nicer.)
6. Proceeded to cut carefully along my sharpie. Make sure not to cut trough both layers of sheet metal. You'll need the underside to bolt the scoop to.
7. I "dry set" the scoop on the hood and got underneath it it to see where the new scoop mounting locations met the sheet metal and i made some little marks on each side of each hole. So i basically wanted 1" tabbies.
8. I took the scoop off and cut little 1" tabs where each scoop mounting hole was going to be. And bent them so the scoop would sit flush on the hood. (do not cut tabs all the way off of course)
9. I then set the scoop in the hole and taped it to the hood
10. Sitting under the hood again, i checked "high spots" in the sheet metal that was obstructing the scoop sitting flush.
11. I hammered and bent all the high spots.
12. After all the tweaking and hammering, the scoop sat nicely.
13. I eyeballed the new scoop mounting locations and drilled 1/4"- 5/16" holes in the tabbies so the scoop studs could pass trough the holes.
14. Put the nuts on the studs and voila...
15. I masked the joint of the scoop and latex caulked it for now. I'm currently looking for ideas on some kind of body filler or different caulking that will hold up to the elements.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Finished Product
Here is the finished product. Its amazing what a difference in looks the scoop will make. You will get all the women staring!
That looks really good, and a nice writeup!
I would prime that lip very well with an etch primer followed by any urethane primer. Then I would use the white all-weather weld-seal to finish it off. You can also tint that weld seal, if you want.
There are other things, but weld-seal remains flexible and is tough as nails.
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
You should come do that to mine when I'm done, as I have no idea what you're talking about.fishbone79 wrote:That looks really good, and a nice writeup!
I'm quite inspired by this method, it's exactly what I was looking for. Although I burnt my dremel motor up halfway through cutting my hood out.
Thanks for the input. So if i go to my local wesco and ask for these items, they will know what I'm talking about?fishbone79 wrote:That looks really good, and a nice writeup!
Re: WRX Scoop DIY Writeup
nice now all we need is someone to put in an STI scoop . that will get the ladies
1990 Subaru Legacy L 89k auto to 5 speed winter daily driver
2004 Subaru WRX 80k
1988 Mazda Rx7 vert > Turbo 2 trans swap
1993 Honda Civic Vx Gutted
2004 Subaru WRX 80k
two thumbs up, very well done.
I don't think that would fit our old body styles at all.beanis05 wrote:nice now all we need is someone to put in an STI scoop . that will get the ladies
