Page 3 of 4
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 12/16^
Posted: Sat Jan 15, 2011 1:53 am
by 93legacylsleeper
Not yet but its my next upgrade along with the trans mount and bushings like you did. I might also throw some Perrin Shifter bushings in my STI shift linkage just to make it that much better.... If I get them in before you ill let you know!
Posted: Wed Jan 19, 2011 3:15 pm
by SiCkSTi04
sounds good to me. tips are always welcome lol
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 03/08^
Posted: Wed Mar 09, 2011 12:19 am
by SiCkSTi04
Re: Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 03/08^
Posted: Wed Mar 09, 2011 1:15 am
by darkcrave
Nice! I so need one of those car mats!?
Posted: Wed Mar 09, 2011 2:40 am
by kimokalihi
Wow incredible fit! Nice score.
Posted: Thu Mar 24, 2011 7:52 am
by SiCkSTi04
thanks!
Posted: Thu Mar 24, 2011 6:02 pm
by zagarus
Damn those mats are awesome! Car is very well built as well. Am I correct in saying they didn't start painting the intake manifold red until version 2?
Posted: Sun Jul 24, 2011 12:57 am
by SiCkSTi04
While the sunroof has been under the knife in my garage, I'd figure its time to take care of a couple small projects.
First up is the fuel pump which has always showed a sign of power loss around sharp corners as talked about in my past thread
http://bbs.legacycentral.org/viewtopic.php?f=11&t=45381
This is how the pump should of looked coming out of the fuel tank
But instead it came out with a missing filter like this...
Found it in the second access side of the fuel tank floating lol
Quick size comparison
And finally a brand new Walbro 255 pump & filter
She starts up just fine
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 07/23^
Posted: Sun Jul 24, 2011 9:34 pm
Damn....yeah that filter bag shouldn't do that
Posted: Mon Aug 01, 2011 5:08 am
by SiCkSTi04
Second was filling in that ignoring gap between my aftermarket radio and the bin pocket.
91 bracket w/ 1.5 din (top) compared to 92 bracket w/ 1 din (bottom)
All finished
Posted: Mon Aug 01, 2011 6:08 am
by Danny-G
Hey I did that too, added the '91 1.5 din box. Also, if you wanna sell the 1 din box I do know someone who would more than likely take it.
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 08/01^
Posted: Mon Aug 01, 2011 8:28 pm
by Timo
looks perfect!
Posted: Tue Aug 02, 2011 12:49 am
by SiCkSTi04
Holding the old bin just in case I go back to the oem radio. I got a couple other things I plan on putting in. Thanks for the feedback guys.
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 09/01^
Posted: Fri Sep 02, 2011 4:58 am
by SiCkSTi04
Seems my radiator has come to an end, found a large puddle of coolant under my car. Not to bad for 265k miles
Currently Looking at Mishimoto's full Aluminum MT or Koyo's OE style radiator but don't care for Koyo's solution creating the AT/MT into one unit for the turbo SS as I don't want the separate transmission cooler. Any input on either of them?
Evidence
Click image below for the video
Posted: Fri Sep 02, 2011 5:40 am
by 91legacyawdturbo
Ok what? 91 had a 1.5 din box? My 91ss has a 1 inch din.
Posted: Fri Sep 02, 2011 1:40 pm
by magicmike
I put my radio below the din box so i could still read it with the cup holder out.
Posted: Fri Sep 02, 2011 3:02 pm
by SiCkSTi04
91legacyawdturbo wrote:Ok what? 91 had a 1.5 din box? My 91ss has a 1 inch din.
I snagged the 1.5 din from a base model legacy.
Posted: Fri Sep 02, 2011 6:27 pm
That is a common failure point for the plastic radiators.
Posted: Mon Sep 05, 2011 9:43 pm
by SiCkSTi04
Plan on going the Mishimoto route. is there anything else I should do? I'm thinking upgrade the water pump to the WRX so I install my oem oil cooler, timing belt, front seals etc.
Josh, did you run the stock thermostat or wrx when using the new style water pump?
Posted: Tue Sep 06, 2011 8:58 pm
by legacymax
Legacy777 wrote:That is a common failure point for the plastic radiators.
failed on my legacy 200mi from home. that was fun!
-Max
Posted: Tue Sep 06, 2011 11:33 pm
SiCkSTi04 wrote:Josh, did you run the stock thermostat or wrx when using the new style water pump?
Stock thermostat
Posted: Mon Sep 19, 2011 1:31 am
by SiCkSTi04
Legacy777 wrote:SiCkSTi04 wrote:Josh, did you run the stock thermostat or wrx when using the new style water pump?
Stock thermostat
Placed a big order for replacement parts including the thermostat, Thanks Josh.
Radiator Update!
Last week I received my Mishimoto Aluminum radiator to find out it was damaged. The vendor I ordered from is sending me a replacement straight from Mishimoto and should have it by next weekend. The plus side is that they dont want this unit back so I'll either fix it, keep as spare or give it away
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 09/18^
Posted: Mon Sep 19, 2011 1:37 am
by kimokalihi
You can give it away to me if you'd like.
Posted: Mon Sep 19, 2011 5:24 am
by Florin1
I'm running an n/a radiator on my tleg. And would love to take this off your hands. I'll pay shipping, and give you some cash?
Posted: Fri Sep 23, 2011 9:43 pm
by SiCkSTi04
Got my replacement from Mishimoto yesterday along with some more subaru parts. I'll deff keep you guys updated if I decide to give the radiator away.
