It's only happened 2 or 3 times, but it still worries me. A couple of times when it was <20 out this loud constant buzzing noise would start coming out from under the dash when I'd go over ~40mph, then would shut off under ~30mph no lights coming on or anything, just the buzzing, loud enough that I could hear it through my stereo turned up as loud as I can stand. It's clearly something electronic, not a mechanical piece, and it is not coming out of my speakers.
Any ideas what could be causing this? Is it something I should worry about?
Odd buzzing sound when cold out
Re: Odd buzzing sound when cold out
Scratch that, got some help elsewhere, nearly certain it's a bad relay, making the same noise my ABS relay was.
Sure its not the speedo cable??
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
mine was the speedo cable...
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
Your wipers on by any chance?
Could be speedo cable too, I haven't tried to fix it yet. I'll try to narrow down where it's coming from next time I hear it Thanks.
So it's definitely the speedo cable, the buzzing changes with the speed, and my speedometer started going all crazy today. Is this something I need to replace? Or is something just loose that needs to be soldered or something?
My speedo does this too when its below ~25 F. I bet its because the lube around the flexible cable shaft has gotten hard from the cold. either hope the friction will heat it up.... or I bet prolonged use in this state will eventually make the cable break prematurely due to the increased friction/wear.
'11 WRX Limited
'94 TW | R.I.P.
