Noise from front of engine
Posted: Sat Aug 13, 2011 6:52 pm
by Baddog
There is this odd noise coming from the front of my friends 92 LS. The crank pulley looks to wobble a little bit. Would just replacing it be the best option?
It sounds like a very faint sound of dried beans rattling in a tin can.
Re: Noise from front of engine
Posted: Mon Aug 15, 2011 5:43 am
by lucas
timing belt might be due.
Posted: Mon Aug 15, 2011 6:26 pm
It could be the bearings in the timing belt idler pullies/gear.
When was the last time the timing belt was replaced? I'd suggest pulling the crank pulley off and removing the timing belt covers to inspect the belt and pullies.
Posted: Fri Aug 19, 2011 5:53 am
by lucas
lol depending on what kinda noise it is id definitely check you timing belt, happened to me. was hearing a funny squeally type of noise thought it was power steering pump lol wasnt the pump. Turns out one of the bearing in the timing gear had gotten hungry and started to eat a disintegrate bearing until about ten were obliterated and she ceased to live. there were shards of bearing stuck in the timing belt
Posted: Fri Aug 19, 2011 7:39 am
by Baddog
Awesome so it looks like I should go ahead and check her belt and pulleys. Thankfully you can get a complete kit on Ebay for around $140
Posted: Sun Aug 21, 2011 8:39 pm
by lucas
some of the kits dont have all the necessary parts from ebay as i found out, you might need to hit up autozone or such. Like you might need a new tensioner and maybe some cam gear im not sure. Hows your harmonic balancer looking while the engine runs?
Posted: Mon Aug 22, 2011 7:42 am
by Baddog
The kit I found seems to have it all. Tensioner. Not sure why it would need a new cam gear. Haven't heard of that one yet. The pulley wobbles just a hair.
